Sorry Same old aerial question
original45
Call Sign: 45
Re: Sorry Same old aerial question
Post by original45 »
Stick the radio on Saturday evening from 7 pm 27.585 usb. You should hopefully hear some chatter as several in Wales join in on a regular net I believe.
Alan Pilot
Call Sign: 163ct220
Post by Alan Pilot »
original45 wrote: 10 Sep 2020, 16:40 Stick the radio on Saturday evening from 7 pm 27.585 usb. You should hopefully hear some chatter as several in Wales join in on a regular net I believe.
Will listen out but i think that Net is South i am North Wales but thanks anyway.
wa10
Post by wa10 »
it should be a tight fit, a clearance fit is no good for unidirectional grp tube, you want an interference fit you have to twist in the opposite direction you wrapped the tape,
if it pushes in its too loose & you will have to take the slack up with the hose clamps,
unidirectional grp cannot be crushed much at all before you hear the clicks & crackles as the linear fibers start parting,
its best to not crush it at all,
good luck with the wind.
W8JI
Alan Pilot
Call Sign: 163ct220
I had to do exactly that "twist in the opposite direction" to get it to go in.
Put 2 or 3 turns on at first but no chance so took some off.
But like i said they where not a slack fit to start with but they where a tight fit with the tape.
Thanks.
Alan Pilot
Call Sign: 163ct220
Well the wind got up last night and still blowing and it's not winter yet so a lot stronger to come but it's bending well.
Think i will have to guy this aerial after all.
Problem i have is i can only guy it on 3 points fairly equal points at that.
Anybody think this will work.
The Collector
Post by The Collector »
3 will suffice.
Get the guys running from the first joint from the top and it shouldn't move much at all. From the second, you'll gave a bit of swaying but still better than it being un-guyed and acting like a fishing rod with a Blue Marlin on the end ;)
Alan Pilot
Call Sign: 163ct220
Just got a new toy to test the new aerial.
This is the SWR close to 555 and drops to 1.01 at around 26.000.
I dont go on the uk fm so not bothered about it going up the higher i go up the frequency.
Opinions welcome.
Alan Pilot
Call Sign: 163ct220
The Collector
Yes that was my plan from the top joint.
Ordered some stuff to do it on Friday so hopefully it will come tomorrow sometime our post can come at 4.30pm but normally 12.30/1pm.
What happened to the hot weather i read about for today and the next couple of day's.
wa10
Post by wa10 »
Alan Pilot
earlier you said you can't understand the tuning chart, you must have the 1/2wave which needs cutting for where you intend using it most,
1/2wave Gain-masters don't have the bandwidth of the 5/8wave, no stub & top coupling capacitor to give a low wide vswr curve,
the 1/2wave will handle more FM power than the 5/8 if you tune it for minimum vswr.
5/8wave GM has a wide low vswr curve with a double dip in the curve like other top coupled antennas such as the X-pole,
highest vswr for the 5/8 across the cb bands is right around ch19 ukFM.
W8JI
Alan Pilot
Call Sign: 163ct220
I should have said i got the 1/2 wave before sorry but i went for the shorter due to neighbors plus a council run home just over the wall.
I am happy with the swr as it is i didn't cut anything off just fitted the brass end to the end.
It will be coming down again to sort out the guying situation and i might just shorten it an inch or so.
But as for the tuning chart goes it made some sort of sense but the diagram showed where to measure it from and that made no sense at all well to me that is so i just put it together and up it went.
Being disabled don't help as i get frustrated when i can't do stuff like i could at one time does my head in as i have to stop and rest but you guy's help with that as i sit and have a look on here for some rest time.
Alan Pilot
Call Sign: 163ct220
SWR is 2 at 28MHz and then below until it hit's 2 again at 25MHz so happy with that and might not cut any off.
The Collector
Just get it lowest where you'll be using it most of the time ;)
Alan Pilot
Call Sign: 163ct220
The Collector wrote: 13 Sep 2020, 15:33 Just get it lowest where you'll be using it most of the time ;)
Going to cut a bit off when it comes down in the next couple of day's try for 1to1 where it is now ;)
The Collector
Just take it steady and take off a few millimetres at a time ;)
Been and collected a 20ft alloy pole today, so I can carry on with some more of my crank-up mast design. Good price too. Only had to wait about 6 months because of Covid!
Just need a slightly thinner 3 or 4 metre one next (this place only sells scaffolding size in alloy).
Alan Pilot
Call Sign: 163ct220
Well it's got guy lines on it now so feel a bit happier with it.
Cut 1.5cm off the end as well and got the SWR where i want it 1.02 on 27.555 and 1.12 on 26.555.
Just need to fasten the anchor end's permanently but that will do tomorrow.
