CB RADIO IN FIBRAGLASS BOAT HELP NEEDED???
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
Can anyone please tell me what antenna i will need to be able to fit a cb radio into my fibeglass boat i take it i will need some type of groundplane or is there another way to go ???
Buick Mackane
Re: CB RADIO IN FIBRAGLASS BOAT HELP NEEDED???
Post by Buick Mackane »
Use a handheld
k40
Call Sign: 26TM788
Post by k40 »
Arn't Shakespear marine antennas?
MrWeetabix
Call Sign: 26TM175
Post by MrWeetabix »
You may need something with a counterpoise included.
If it doesnt dwarf the boat, I think the Gain Master may do the trick. Its essentially a dipole in a fibreglass case right?
Post by The Collector »
There are fibreglass aerials made for marine use that don't need a groundplane and I'm sure I've seen one for 27mhz that does the same. Google is your friend and may be able to find the thing.
Just don't drill through the floor of the boat to try and fit a 7ft Firestik in it ;)
Edit... for example:
https://www.ebay.com/itm/273765686821
https://www.ebay.co.uk/itm/174268510287
..and if you want to look the part and you just want a basic, 40ch radio, youll need a Quasar or Jesan radios -
cb4ever104
Post by cb4ever104 »
The Collector wrote: 20 Jul 2020, 18:48 ..and if you want to look the part
Then you'll need one of these too then :)
ChrisMagpie
Call Sign: 26TM553
Post by ChrisMagpie »
WARLOCK wrote: 19 Jul 2020, 20:53 Can anyone please tell me what antenna i will need to be able to fit a cb radio into my fibeglass boat
https://www.ebay.co.uk/itm/SIRIO-CRUISE ... SwvoZeJwdO
Have you been on Bullseye? :D
This wasn't purchased using stolen funds from that "I want to buy a narrowboat and put a CB radio in it. Give me money please!" topic from a few years back was it??? :)
MrWeetabix
Call Sign: 26TM175
How did you get on Warlock?
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
HI MrWeetabix , not done anything yet but when i do get around to fitting the antenna i have decided to making some form of a metel groundplane ?
WARLOCK wrote: 25 Jul 2020, 09:07 HI MrWeetabix , not done anything yet but when i do get around to fitting the antenna i have decided to making some form of a metel groundplane ?
If you're going up canals etc then use aluminium, but if it's going out to sea, use stainless steel.
As long as it's not a narrowboat ('cause it would look stupid), you could always make a roll over-type bar like on cars and you could mount the aerial on that.
