zatagi 550 amp know how
68ci1954
New User
New User
Call Sign: 68ci1954
Post by 68ci1954 »
Anyone know what the jack plug SOCKET is used for on the front panel of a Zatagi 550p amplifier ....tia...
wa10
Re: zatagi 550 amp know how
Post by wa10 »
Its wired in series with the on/off switch, a piece of 2 core wire with a switch at one end & jack plug at the other gives you remote on/off.
W8JI
68ci1954
New User
New User
Call Sign: 68ci1954
Post by 68ci1954 »
wa10 wrote: 30 Jun 2020, 18:26 Its wired in series with the on/off switch, a piece of 2 core wire with a switch at one end & jack plug at the other gives you remote on/off.
Thank`s
