Brand new studio mics for under £20!!
- George EI7KO
- Call Sign: EI7KO
Re: Brand new studio mics for under £20!!
Better than feeding the Mike a fraction of its operating voltage anyway. As for the lead I'd just make one. Your rig should have a rca jack on the back for ptt. That's what I use on my 920 to key it. I wouldn't be banking on a mixer for a Tenner being much good. I've the 802 here. Think I gave 40 euros for it used. Has parametric eq on each channel etc.
BLUE LED'S ARE BEST!!!!
- Black_Pirate
- Call Sign: 26TM034
301672491319 item no ...
Like this then...
Like this then...
Didi modes (JS8 on 27.245 usb) txt messages via radio lol at minus- 10 to 20 db..... See FB page...
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
- George EI7KO
- Call Sign: EI7KO
Someone said they were not available. I just bought one, This is phantom powered too
http://www.ebay.co.uk/itm/Top-Mic-Conde ... 1355313013
should have it by the end of the week all going well
- George EI7KO
- Call Sign: EI7KO
I wouldnt buy that one mate. If you look at the EQ on it it only has low and high. Mid is the one youre really interested in with radio as you want to boost the mids to around 2k to make your audio 'articulate' I reccoment the Behringer Xeynx 802. Has more channels than you need but you can always run other stuff through it....that mixer is crap....buy cheap buy twice as my old man always saysBlack_Pirate wrote:301672491319 item no ...
Like this then...
- Black_Pirate
Cheers and thanks for the advice I will keep an eye out for your recommendations ..
Now have the mike and boom here ......
Looking forward to experimentation
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
- Tigersaw
- Call Sign: GW6RRL
Has a compression knob too which seems to do 'something' - add distortion and noise would be my description.
- George EI7KO
- Call Sign: EI7KO
Lol. Do for a start I suppose.
- chazwozza
- Call Sign: 26CD172
All great mics shame they all sound the same through my 2 quid speaker
- George EI7KO
- Call Sign: EI7KO
2 quid? Flash git
- Tigersaw
- Call Sign: GW6RRL
Well its all assembled - with the mixer levels all set at 0dB (except the mic pre-amp at -10dB) , fed into the radios data port at line level and it works very well along with the homemade key switch.
Time will tell if I like using it and if there is anything to gain from it, but its fun putting it together and cost almost nothing thanks to some 'free' amazon vouchers I got in a promotion.
Might explore the USB effects port and software sometime, might be interesting to 'contest contest 5 and 9' as a dalek.
- Black_Pirate
If you can pass the audio thru the computer there are some great "effects" I saw on YouTube...one is like an old graphic equalizer...with some fantastic audio settings....maybe of interest to you..
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
- Tigersaw
- Call Sign: GW6RRL
it comes with downloadable software and plug-ins, you can have all sorts of echo, reverb, processing, special effects.
There might be an overdriven zetagi simulator I can use.
Or maybe a frequency inverter so lsb sounds like usb, that will confuse them.
- George EI7KO
- Call Sign: EI7KO
Mine arrived today and I am happy to say that it is indeed phantom powered. Few more bits to gather yet, and I will be ready to rock
- gmham
- Call Sign: 108TM154
Still searching for UK supplier of 1.5v battery powered version ! Seems you lot have cleared the UK off all supplies !!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- George EI7KO
- Call Sign: EI7KO
Just bear in mind the battery version is not a true condenser mike as such. They have an electeret capsule in them. Its not that big a deal to provide phantom power....
