The old Melos - CB conversion help required
Re: The old Melos - CB conversion help required
Last one. White wire from output wire (to lead going to radio) is attached to dB selector switch - middle setting???
Well as I didn't get any responses, I went and did the only thing I possibly could and I bought another one! Although it's been done differently input/output-wise, I should hopefully be able to suss out the wiring and see if I can find the fault inside the first one.
I did say hopefully
I did say hopefully
Any one got any pictures or a diagram of how the green line de 1 is wired inside? Ive bought one that had been converted to cb. But its been dewired and all the phono inputs/outputs have been dewired too. All the variables are still wired to the board. Thanks mick
Mine are both plain black-fronted ones. Do you know if they'd be exactly the same inside as the green-lined one though (yours is the same as the Echoman-branded version I think)?
