Paddington
Scanning radio frequencies for the South East
hamtrektng
Call Sign: 2E0TZR
Paddington
Post by hamtrektng »
Also looking at Paddington station DMR freq. Anyone with info to share please do pm me.
bigbloke
Re: Paddington
Post by bigbloke »
453.550 DMR . its a CAP+ system though so multiple other channels
hamtrektng
Call Sign: 2E0TZR
Re: Paddington
Is it encrypted and do you know the tallkgroups and colour codes?
Chris64ex4
Re: Paddington
Post by Chris64ex4 »
hamtrektng wrote: 04 Sep 2018, 23:25 Is it encrypted and do you know the tallkgroups and colour codes?
Paddington not encrypted. Don't know about the talk groups but it's colour code 8. There is another DMR channel at Paddington on 453.9 MHz also colour code 8.
Reading station on 453.275 MHz colour code 5. Reading traincare Depot on 435.55 MHz also on colour code 5.
hamtrektng
Call Sign: 2E0TZR
Re: Paddington
Thanks Chris for the helpful info. When I go up in 2020 I will see if I can do more decode. Merry Christmas and a new year to you bud.
Chris64ex4
Re: Paddington
hamtrektng wrote: 26 Dec 2019, 00:39 Thanks Chris for the helpful info. When I go up in 2020 I will see if I can do more decode. Merry Christmas and a new year to you bud.
No problem and happy new year to you. Ive got a couple of Baofeng 1801 on order which should help me with Talkgroups etc.
Chris64ex4
Re: Paddington
Chris64ex4 wrote: 21 Dec 2019, 14:42
It looks as if Paddington alternates between 453.550 and 453.900 MHz every so often. There appears to be alternative frequency for Reading station but I know not what it is.... :shock:
Chris64ex4
Re: Paddington
Chris64ex4 wrote: 31 Dec 2019, 14:05
No luck with talkgroups as yet, there must be something I’m not doing right with the Baofeng 1801’s.... :shock:
neil57uk1
Re: Paddington
Post by neil57uk1 »
You dont need the talk groups. Just put the frequencies in your scanner at it will do the rest.
Chris64ex4
Re: Paddington
neil57uk1 wrote: 23 May 2020, 19:22 You dont need the talk groups. Just put the frequencies in your scanner at it will do the rest.
I realise that (I took the AR-DV10 to work with me which is how I got the frequency / colour codes) but the question was asked about talk groups etc. Hence my leaving the DV10 behind and taking the Baofeng 1801 instead. In theory at least if you bang in the frequency and colour code the Baofeng should display the talk groups when the channel is in use. Possibly need to take the DV10 up again, not going to Paddington all that often at the moment to be honest.
sah367
Re: Paddington
Post by sah367 »
Hi.
I realise this is an old thread, but I was in London last weekend (21st January 2023) and got hits on :
Paddington
453.5500 - Colour code 8
453.9000 - Colour Code 9
456.4000 - Colour Code 9
460.0500 - Colour Code 8
Reading
453.1750 - Colour Codes 4 and 12
453.2750 - Colour Code 5
459.7750 - Colour Code 5
459.6750 - Colour Code 4
Hope that is of use or interest to someone!!
Scooter
Uniden UBC-75XLT / UBC-125XLT // Whister TRX-1e
DuncanM
Re: Paddington
Post by DuncanM »
That's both the inputs and outputs
Paddington
453.550 -460.050
453.900 shouldn't that be 460.400 or is that a simplex
Reading
453.175 - 459.675
453.275 - 459.275
453 frequencies unless they are simplex have a 6.5 MHZ split. Stations can be either simplex or duplex
DuncanM
Re: Paddington
Post by DuncanM »
Chris64ex4 wrote: 12 Jan 2020, 12:23
Its not impossible to have more than one frequency at a station. Liverpool Lime Street has Network Rail who manage it on one frequency and Avanti on another, the MerseyRail on the low level trains a different one again
sah367
Re: Paddington
Post by sah367 »
DuncanM wrote: 26 Jan 2023, 18:58 That's both the inputs and outputs
Paddington
453.550 -460.050
Reading
453.175 - 459.675
453.275 - 459.275
Radio Reference showed me 4 frequencies for Network Rail:
453.550 & 460.050 - user name "Network Rail Infrastructure Limited Paddington"
453.900 & 460.400 - user name "Network Rail Infrastructure Limited"
(Search Network Rail at postcode W2 1HQ +1mile)
which I saved into the scanner and got hits as reported! :?
I need to have a day at the various Central London stations to get more info (I have frequencies shared between Paddington, Euston and Kings Cross from RRUK!)
Scooter
DuncanM
Re: Paddington
Post by DuncanM »
If you are close enough you will hear both input and output, if you look at the RRUK frequencies they have an R or a T beside them, R for Receive (output) and T for Transmit (input). what you put has 2 R's and 2 T's
