Digital frequencies Glasgow including tetra for aor dv10 ?
- Call Sign: TV54
Hi I know we can’t listen to police but anyone have a aor scanner that can pickup tetra for other places or digital frequencies for aor dv10 ?
- Metradio
- Call Sign: G7HID
Re: Digital frequencies Glasgow including tetra for aor dv10 ?
Newcastle Metro Trains
Nottingham Trams
London Tube Network
Northern Ireland Ambulance & Fire
All reported in the clear..
Mike
Nottingham Trams
London Tube Network
Mike
Plus Dublin Luas Tram Network
Glasgow Underground (think its clear)
- Call Sign: MM6AAM
Daft question but does in the clear mean you can listen to these organisations on this radio? Fee free to pm me rather than posting
- Metradio
- Call Sign: G7HID
It is no secret, unencrypted (in the clear) Tetra can be received by the AOR DV1 and DV10, also by various dongles that can be plugged into a PC..Maybolelistner wrote: ↑25 Feb 2021, 14:57 Daft question but does in the clear mean you can listen to these organisations on this radio? Fee free to pm me rather than posting
Mike
- Call Sign: MM6AAM
Hi Mike ,
Have sent you a pm hope this is okay!
- Metradio
- Call Sign: G7HID
Will reply to your PM here, I am no expert on PC dongles so you would do better asking your questions on here as you would reach a wider group of expertise on the subject..
Mike
Mike
- Call Sign: MM6AAM
Are you any good with the set up? And also with those names you mentioned above can you receive these nationwide? Just trying to work out if it’s worth my
While trying to pursue this side of the hobby
- Metradio
- Call Sign: G7HID
I had a dongle years ago but migrated to digital scanners that are not tied to a PC and can run stand alone, also a couple of scanners I use are portable - which you can't easily do with a dongle.
Apart from the Northern Ireland example the other examples are limited to their local are and in the case of London Underground the signal is not receivable very far from the tube stations and overground lines..
Mike
Mike
With tetra and other radio networks in the uk none are nationwide, only radio network nationwide is airwave the encrypted emergency service network.
Tetra infrastructure is very expensive so no point in say London Underground network having base stations in Manchester or Glasgow etc.
Most if not all private networks are clear and limited range from where they operate.
If near the coast it’s been reported some off shore wind farms use tetra. But not all.
Some onshore ones also use it also but ones around me still use analog.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
