HEARD SOMETHING ON 397.3000MHZ DMR SCANNER- GLASGOW
GlasgowTransmission
Call Sign: TV54
Post by GlasgowTransmission »
Heard someone talking on 397.3000 on my SDS100 digital scanner showed the colour code but couldnt make out what thet were saying think its encrypted its a weird frequency but someone defintely using it, any ideas?
Glasgow east end
scottyboy
Re: HEARD SOMETHING ON 397.3000MHZ DMR SCANNER- GLASGOW
Post by scottyboy »
Strange one as I don’t know any DMR radios that drop below 400.000 in the UHF band.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
GlasgowTransmission
Call Sign: TV54
It had to be encrypted anyway and was definetely showing a colour code of 7 but not idea
scottyboy
Post by scottyboy »
Is it possibly a ghost transmission from a nearby user? I’m struggling to find anything remotely near that frequency
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
scottyboy
Post by scottyboy »
Do you know if it Was simplex or through a repeater?
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
GlasgowTransmission
Call Sign: TV54
Dont even know difference between them too was into scanning for years then stopped and only recently got a digital scanner again and started learning colour codes dmr etc so might be a ghost transmission but not sure about simplex or repeater someone was dedinetely takking in it but sounded scrambled voice and colour code 7 kept showing until they stopped talking then it continued searching new frequencies
scottyboy
Post by scottyboy »
If you listen in analog a repeater when in use sounds like a jackhammer being used.
Simplex you hear a lighter noise like a skipping rope hitting the ground is the only way I can describe it.
Have you heard it since you first heard anything?
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
GlasgowTransmission
Call Sign: TV54
Nope not again right enough but that day I posted definetely something there
fmdx
Post by fmdx »
Did your scanner give any more info other than colour code? ie did it give talkgroup etc (not that i want you to post it on here!) and as scotty said how did the transmission sound on the scanner?
This frequency lies very close with the tetra comms used by emergency services in UK but i highly doubt it would have been a terminal even if it were the simplex ch you were picking up.
As op says prob something strong from nearby and your scanner just picking up some stray signals or overloaded etc what antenna you using ?
