Hi,
Can anyone tell me if 147.8MHz is used in Scotland for fire brigade call outs ?
TIA, Al
Fire Alert Pagers
Re: Fire Alert Pagers
Yes. I monitor it regularly.
457,489Mhz is the default fire ground channel (Channel 3)
- spykeboi
- Call Sign: 2M1SB
If your local fire service is on the retained duty system, volunteer or day manned they can be very busy during peak wildfire season.
How is it set up, is it wide area so a blanket signal for certain pagers or is it localised for which ever station they are paging for?
Where I live there is mainly whole time stations but retained stations about 8 - 10 miles away.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- spykeboi
- Call Sign: 2M1SB
Regional up to about 20 miles distance. Tone only. Three bursts at a time.
- spykeboi
- Call Sign: 2M1SB
