Warrington 455.750
Scanning radio frequencies for the North West
Carlos
Call Sign: mm12
Re: Warrington 455.750
Post by Carlos »
I've found 440.225, 455.775, 453.9875, 445.6125, 455.750, also 456.975 (a warehouse or distribution centre, but which, there are loads around here) all on DMR, on 456.400 on NFM which is possibly a shopwatch in St Helens
DuncanM
Post by DuncanM »
You still haven't yet said which scanner you have. Some have continuous from 25 to 1300 mhz, some have gaps.
Carlos
Call Sign: mm12
Post by Carlos »
Bottom of page 1 the list with freq, ICOM IC R5
milly
Post by milly »
Carlos wrote: 14 Jan 2021, 22:43 I've found 440.225, 455.775, 453.9875, 445.6125, 455.750, also 456.975 (a warehouse or distribution centre, but which, there are loads around here) all on DMR, on 456.400 on NFM which is possibly a shopwatch in St Helens
Exact same text posted by someone else on another bulletin board......
'carlos' using an R5 but can determine that a dmr freq is a warehouse or distribution centre?
He can listen to paging data and say it's an 'airport'?
Anyone else find this rather suspect?
Metradio
Call Sign: G7HID
Post by Metradio »
Nowadays it is not unusual :-(
Mike
