hi all I have these shopwatch freqs does anybody know if they work as going away there for 3 days next month
Blackpool - Lancashire - 456.9500 462.4500
Blackpool - Lancashire (BID) - 453.1000 459.6000
Blackpool - Lancashire (BID) - 453.9250 460.4250
blackpool freqs wanted and shopwatch
Re: blackpool freqs wanted and shopwatch
Hi pal 456.9500 is Preston cctv, 453.9250 is Blackpool cctv. 453.1000 is security but can't identify the user.
cheers bud just summit to listen to after a good night out
- chin913
- Call Sign: notafullone
453.100 is one of the ever changing trunking freq bae use and there security , you may hear me one night on there ..listen for fire control ...and the callsigns from a1-a18 then b-1 so on and c-1 so on and d-1 so on... other freq they use are 453.475 mhz 453.600 mhz 459.925 mhz 456.900 mhz 456.750 mhz 460.425 mhz.. That should cover the trunkning freqs over here, no point giving you the input as you wont hear them..Sorry forgot to say Bae at barrow in furness... you should pick them up no probs from over the bay
Warning: Dates in Calendar are closer than they appear.
https://www.youtube.com/user/mrblogger913
https://www.facebook.com/groups/furnesshamradio/
