Page 1 of 1
Shopping Centre switched to DMR
Posted: 27 Apr 2019, 22:27
by Vrillon
A certain local shopping center switched to DMR recently I flipped on the old SDR and whalla I had the CC TG in a jiffy the whole lot seems to be on one frequency. So it's not like a CAP+ with loads of different frequencies and TGs. But when I popped the details on my trusty MD380 I didn't seem to pick it up. I have programmed in the local hospital and the town shopwatch ok - just can't seem to get this to work - any ideas ?
Re: Shopping Centre switched to DMR
Posted: 28 Apr 2019, 12:47
by thelad
Most likely a RAS system. Is the Rx LED showing.
Posted: 28 Apr 2019, 23:12
by Vrillon
The SDR not showing a RAS system it saying its DCC The green light on MD380 is blinking green rx light but no audio.
I tried it on my RT3S also same thing blinking green rx light but it's coming through my SDR ok
The signal is a bit weak though i'm not sure if that might be an issue
Posted: 29 Apr 2019, 04:27
by thelad
I find if its a short Tx or weak signal my DSD takes a good blast to show that the system has RAS.
