Hi all.
Just picked up a AOR AR-DV1 Scanner.
Being new to scanning any help in using the said radio would be a great help.
Just had a discone antenna put up 25 feet in the air.
Any frequencies on any modes would be a great help to.
Im in Nottingham UK.
Many thanks to all in advance that can help.
AOR AR-DV1 Scanner Analog + Digital Modes
- Call Sign: G0CRB
Re: AOR AR-DV1 Scanner Analog + Digital Modes
I have the DV1 as well, Had mine about a year ago. But the freq around where I live would probably be no good where you live. I would suggest that you search small areas at a time until you find something interesting. Then store them into the different banks.I store Ham freq in one bank then 446 in another bank etc then. I would suggest that in the Aircraft range of freq don't use the Auto mode, use the DV1 in AM mode as it seems to work a bit better.
Many thanks for your reply.
Will have a look a around and see what i find and put them in some bank order as advised.
Any more advice from any other members on using the Aor ar-dv1 with frequencies and any other help etc would be most appreciated.
Thanks again.
Thanks again.
- Andy
I've had my DV1 for a few years now and it's pretty decent. Around here (Manchester) there is lots of DMR activity on 453 and 456 MHz. There's also some around 440/441 and 445. Get ready for the infamous DV1 'dalek voices'!
'SOMEONE GET ME A SAW!'
Andy.
Andy.
Will have a look around them numbers.
May i ask what antenna you are using.
I forgot to ask Andy.
What is the infamous DV1 'dalek voices'!
Paul.
Paul.
- Andy
Hi Paul. I have a selection of ironmongery in the air. My main antenna for UHF is an amateur band 432 MHz band yagi. It's fixed pointing to the west across Manchester as I have hills behind me to the east. I also have a wire dipole for 145 MHz in the loft which works quite well on VHF and UHF.
The DV1 'dalek voice' is a rough effect that appears when both slots are in use on DMR. You'll know it when you hear it!
I've just picked up a used AR5700d receiver and not surprisingly it doesn't seem to suffer from the effect. And it bloody well shouldn't at the price.....
Andy.
Andy.
Spot on Andy and many thanks for that.
