Antenna options, cannot attach to building.
As stated, cannot permanently fix anything to the exterior of the building, yard space of about 20ft by 10ft where semi permanent structures are a possibility. What are my options?
(Other than taking up another hobby)
Re: Antenna options, cannot attach to building.
What for cb or ham.
- Mudslinger
Concrete a pole into the ground and attach an antenna to that. The pole can double up as a washing line pole.
http://morsesagas.blogspot.com/2017/03/ ... na-at.html
Have a read... I've done something similar and it works.
Thanks chaps, some stuff to look at.
It depends on what you are going to use it for ? Is it to talk to the locals ? If so you want it vertical. For dx vertical or horizontal. Can't you put a flag pole up and use it as a antenna ? Even fake tv antenna like use the pole as the antenna with a fake tv antenna at top ? Lots of ways of doing it. Just got to make it look legit. If none of that is possible maybe use a drain pipe and hide a wire antenna behind it but only if it's plastic. You can make a t2lt out of rg58 coax and hide that behind a drain pipe. It will work but you will have limited range.
- Tin soldier
You could also use a cast iron parasol base, with some sandbags around it, or if it's a concrete base, fasten it down.
Aluminium tube and a silver rod etc.
- MrWeetabix
- Admin
- Call Sign: 26TM175
if you are only using the radio whilst the car is parked up, you can get a drive-on base to slot a scaff pole into. a few guy ropes for safety and you're good-to-go.
The one I have even tilts to make it easier to put up/down
It makes it easier to have a quick getaway when the anti-dogging police catch him up the moors againMrWeetabix wrote: ↑09 May 2023, 20:38 if you are only using the radio whilst the car is parked up, you can get a drive-on base to slot a scaff pole into. a few guy ropes for safety and you're good-to-go.
- lambrettadave
- Call Sign: TM455
[quote="
[/quote]
[/quote]
Why does it look like someone has relived themselves on the wheel
[/quote]
[/quote]
It makes it easier to have a quick getaway when the anti-dogging police catch him up the moors againlambrettadave wrote: ↑13 May 2023, 19:32 [quote="
[/quote]
[/quote]
That's NOT wee! I told you, it's a dogging site.. ewww yuk
- Call Sign: 26TM553
[/quote]
[/quote]
It's perfectly legal
https://www.stupidlaws.com/it-is-legal- ... e-vehicle/
- MrWeetabix
- Admin
Funny story, I was on holiday in Wales last year and took the chance to find a local high spot overlooking the coast. Found this great car park and I was working into NI and all the way up the west coast, brilliant..... then a local lad told me it was a notorious dogging spot! haha.The Collector wrote: ↑13 May 2023, 10:10It makes it easier to have a quick getaway when the anti-dogging police catch him up the moors againMrWeetabix wrote: ↑09 May 2023, 20:38 if you are only using the radio whilst the car is parked up, you can get a drive-on base to slot a scaff pole into. a few guy ropes for safety and you're good-to-go.
Well, thats my story and I'm sticking to it!
- lambrettadave
- Call Sign: TM455
Hahaha should have just went to st Mary'sMrWeetabix wrote: ↑15 May 2023, 22:20Funny story, I was on holiday in Wales last year and took the chance to find a local high spot overlooking the coast. Found this great car park and I was working into NI and all the way up the west coast, brilliant..... then a local lad told me it was a notorious dogging spot! haha.The Collector wrote: ↑13 May 2023, 10:10It makes it easier to have a quick getaway when the anti-dogging police catch him up the moors againMrWeetabix wrote: ↑09 May 2023, 20:38 if you are only using the radio whilst the car is parked up, you can get a drive-on base to slot a scaff pole into. a few guy ropes for safety and you're good-to-go.
I heard that the bloke in the shop asked where he was planning on using this drive-on aerial mount, and after being told it was for use on this particular dogging site, he said he recommended something that would give him an almost instant erection.
