Hi
I ve been programing my ht600e and gp900 etc with an old slow laptop.
this has since died, is there a way of using a faster machine to program these radios?
Many thanks
ht600e and gp900 programing
- Call Sign: m5jts
- Metradio
- Call Sign: G7HID
Re: ht600e and gp900 programing
Have a word with your local charity shops, they sometimes get donated old working 386's and 486's...
Mike
Mike
- DX-Digger
- Call Sign: TM205
Try running the program in Dosbox
https://sourceforge.net/projects/dosbox ... e/download?
Basically you use the dosbox program to mount the directory with you motorola software as a harddrive, you then log onto that drive from within the dosbox program and run the ht1000 program.
You can also create a config file that sets virtual comports to link to your real comport, but handles the data rates etc.
I use it for programming old tait and Icom radios that dont like windows 10 etc.
Hope that helps
Oh and there is a function button for slowing the processor speed reported The help file explains it all.
Hope that helps
- Metradio
- Call Sign: G7HID
Part of the problem with programming old Motorola radios is the way the serial port is controlled, most Windows PC's will run the Motorola programs under DosBox but fail to communicate correctly with the radio..
Mike
Mike
