Westland 707 FM Power Regulator Mod
Phuture
Post by Phuture »
FM Power Regulator
Remove mode switch and flip it over
There’s a yellow then white/red then a link to an orange wire
Cut the link to the orange move the white\red to the orange
Then link the yellow to where the white/red came off.
The other side of the orange has a link DON'T remove that side of link.
Just wondering, what does the above mod resolve in the original unmodified Westland 707? Are there problems with the 707's output power on FM straight out of the box?
Otter
Call Sign: 26TM439
Re: Westland 707 FM Power Regulator Mod
Post by Otter »
I think the Westland runs FM power flat out. Quite often this will lead to the output stage eventually going up in smoke. Reducing the FM power level down to the AM carrier level stops this from happening.
Phuture
Post by Phuture »
Ah, I see. Thanks Otter.
Phuture
Post by Phuture »
So the problem happens even when the FM output power is set to 4W, not whatever the maximum achievable output power can be set at? How is the output power overload possible if set lower, or is the overload affecting other parts of the circuit where the current level is set elsewhere?
Otter
Call Sign: 26TM439
Post by Otter »
No, on the Westland FM runs at the SSB power limit I think. The mod is to take the power down to 4W (or the AM power).
Phuture
Post by Phuture »
Otter wrote: 29 Aug 2022, 15:18 No, on the Westland FM runs at the SSB power limit I think. The mod is to take the power down to 4W (or the AM power).
Ahh, now I see even more clearly. :D Thanks Otter. :thumbup:
Edd200sx
Post by Edd200sx »
I did a write up on this only a couple of months ago…
DELETE MY ACCOUNT
Phuture
Post by Phuture »
Edd200sx wrote: 29 Aug 2022, 20:51 I did a write up on this only a couple of months ago…
Yep, hence your "FM Power Regulator" instructions in my OP. :)
Here's the post for anyone wanting the other mods:
viewtopic.php?p=551983#p551983
Edd200sx
Post by Edd200sx »
Phuture wrote: 30 Aug 2022, 10:05
It stops fm being regulated by ssb.
Am fm set together with the mod
DELETE MY ACCOUNT
