Hi all. I moved house recently so I thought I better go on the Ofcom website and change my details. I changed my address no problem then I had a PDF file sent to me and it shows my mailing address as my new address but it also says station location at my old address. I can not see anything on the website to let me change this. Any ideas?
Cheers...Rich
Change of address
- NightProwler
- Call Sign: 163TM186
Change of address
- EssexHam
- Call Sign: M0PSX
Re: Change of address
Hi Rich,
I've just had a look for you - Each amateur radio licence has its own “Main Station Address” – Select each licence individually and press “Amend” – this will give you the option to amend both your mailing address and your main station address.
Is that what you were looking for?
Pete
Pete
- NightProwler
Ahhh ok I shall take a look later and see if I can change it.
Thank you Pete.
Thank you Pete.
- NightProwler
