Replacement long 27 mhz telescopic antennas ?
- Call Sign: 45
Anyone found any that were long over 5' that stand up to use and actually work ok.
Looking to upgrade the intek 520 ht some.
Already see a improvement over standard with the Albrecht 21' but looking for something like the binatone long ranger antenna types of the 80s long telescopic jobs.
Prefer bmc fitting but could adapt other I'm sure
- lambrettadave
- Call Sign: TM455
Re: Replacement long 27 mhz telescopic antennas ?
Have you thought about a so239 type CB antenna?
Like a ml145 type antenna
- Call Sign: 45
In honestly Dave I put a sirio carbonium on it yesterday but I felt it too heavy .
I have a ml 145 ,will try that tomoz may be a touch lighter.
Probably the way to go mate in honexty
3/8th's mount and a 7ft Firestik I reckon. That'll build up those wrist muscles while you talk too
Don't they do one of those unfolding military-type handheld aerials for 27mhz yet?
- Call Sign: 45
Yes saw a folder last night about 7£ but after a friend's experience 3 broken one after another I'm not too excited about them.
For sure the mobile ships are the better option however their a little too big to be carrying around where as a retractable telescopic will shorten simply.
Maybe cb isn't so popular so as the Chinese won't build so many antenna options like they do for baofeng.
After sorting a few crushed wires inside this intek and rust !! I'm amazed by its receive.
Compared to my eurozone it's fantastic like Steve Austin biopic ear lol
For lightness with a reasonable distance in mind, perhaps either a 4ft Cherokee Dial-a-Match or Half-Breed would suffice? The coils are smallish and you could even cut the whip into 2 for portability and use one of those bullet-shaped whip connector blocks. A 3/8" adapter should suffice.
Or try your portapak aerial as a temporary comparison and maybe buy another at some point.
If you're going 3/8 base you might as well get a telescopic 1/4 wave
https://www.radioworld.co.uk/buddipole- ... copic-whip
- Call Sign: 45
Now they look interesting and long could be ideal . Anyone used these ?
I'd just be worried that the strain would be too much on the handheld radio's plastic housing to mount it directly.
Now if one of those could be mounted on something and then a patch lead used inbetween, then that'd be interesting. As you'd be using a patch lead/ co-ax to connect it, you could swr it in too
- Call Sign: KAAN9182
Hello gentlemen,
New on this sight. I am in the US and gather many of you are not. I use a midland 75-822 to monitor 11 meters at my second home on the beach. I recently got a sturdy telescopic for it on Amazon. Maker is UAYESOK.
Not sure of availability ooutside of US. There is also a seller on Ebay, Jeepbangkok, who makes a large 27Mhz collapsible. It matches great and TX/RX is very good BUT in a strong wind by the beach it twisted up. I have had the UAYESOK for a shorter time. But it seems to work well and is the sturdiest telescopic I have found. I have had the onne I mentioned from Ebay and the one from Cobra (which was sturdy but shorter and limited in range), the UAYESOK seems to be the best so far. I must admit I made longer distance contacts with the Ebay one but I have not had the UAYESOK as long. Final note as someone mentioned the so called tactical, aka military, found one here locally for 27Mhz. Broke in a week. Replaced by seller. 2nd broke in 2 days. I gave up. It was the only 27Mhz tactical I found.
I use two in a 3/8 dipole centre, you need to treat them with some respect when opening and closing but they've stood up to some high winds and perform well. They're very light and small enough to fit in a rucsack or suitcase but I'm not sure I'd want to walk around with one on top of a handsetoriginal45 wrote: ↑24 Sep 2021, 09:38 Now they look interesting and long could be ideal . Anyone used these ?
- lambrettadave
- Call Sign: TM455
If you are thinking of dxing with your handheld why not get a antenna like a starduster or similar tripod type antenna.
Or even a tripod for a camping satellite dish that can be pegged down and then you could use any antenna you want
- Call Sign: 45
You know what Dave that's a blooming good idea, I got a couple of tripod type antennas lemm and a sirio signal keeper..
I will have play with those. Tested a sirio 145 worked Well standing alone
Have picked up a second midland 77 805 with another original antenna and the rubber duck type too but intend to make a adapter for the telescopic antenna to fit the intek too see how that works
- lambrettadave
- Call Sign: TM455
This is what I also thought of as these can be pegged down and they are light too
- Call Sign: 45
Lol I got one like that too, came with some ham gear I bought few years ago. Had some light weight alloy swadged poles sets too.
Will try and put it all together see how it goes.
I think I I was just singularly minded on a antenna to fit straight on the radio in ways.
yes I think they would defo need ground pegs.
I wonder if theirs a height the sirio signal keeper works best at ?.
