Anyone seen one before?
Can't find any pictures on the web.
I picked it up years ago can't remember where, sent pix to wallen antennas but they didn't get back to me.
Modulator 2000
- k40
- Call Sign: 26TM788
Modulator 2000
Re: Modulator 2000
One thing for sure that design must have worked cause there are endless copies everywhere, good luck in the search for the provenance (lol) of this one.
- Mudslinger
Re: Modulator 2000
At least two people had the base version in my town back in the early 1990s.
They worked ok but not great, they were a legal antenna due to the loaded radiating element, and also had loaded groundplains.
There was a feature in one of the CB mags back in the day where it said that they wre made from Duralumin.
Never used the mobile one though.
Re: Modulator 2000
I had the modulator 2000 back when they first came out, it performed about the same as my slightly shorter wallen modulator & a little behind the longer stiffer riding bullwhip.
W8JI
- SgtBilko302
- Call Sign: 108ct302
Re: Modulator 2000
I had one back in the early 90's. Worked ok but don't leave it outside on the vehicle on a hot day.
Mine melted at the bottom where the 3/8 fitting meets the plastic. Bought mine new from Truck King i think. £20.
Paul.
Paul.
Re: Modulator 2000
I'd be concerned about using it whilst mobile. If it was to hit a tree, It'd probably either break the casing, or worse still, kink the car's bodywork if it was mounted through the metal. Probably best kept for homebase useage, static mobile or mainly as a collector's item.
