Hi All !
I own a IC-2200H which I am really enjoying on 2M. Although an early model, it says in the manual it supports digital modes.
Can I put a UT-118 into it for DSTAR ? I dont need the APRS, just looking for digital/dstar connectivity.
Many thanks in advance
Alan/Alze/M7ALU
IC-2200H Dstar ?
- Call Sign: alze
- SgtBilko302
- Call Sign: 108ct302
Re: IC-2200H Dstar ?
I had one of these sets a few years back. Yes you can fit D-Star into them.
Type: Amateur VHF transceiver
Frequency range: TX: 144-146 MHz (Europe)
TX: 144-148 MHz (USA)
RX: 118-174 MHz
Mode: TX: FM/FMN (DV (D-Star) option)
RX: AM/FM/FMN (DV (D-Star) option)
RF Power output: Hi: 65 W
Mid1: 25 W
Mid2: 10 W
Lo: 5 W
Receiver system: Double conversion superheterodyne
1st IF: 21.7 MHz
2nd IF: 450 KHz
Sensitivity: 0.133 uV (12 dB SINAD)
Selectivity: FM: >6 KHz (-6 dB), <14 KHz (-60 dB)
FMN: >3 KHz (-6 dB), <9 KHz (-60 dB)
Image rejection: >60 dB
Voltage: 13.8 VDC +/- 15%
Current drain: RX: 0.8-1 A
TX: Max 15 A
Impedance: 50 ohms / SO-239
Dimensions (H*W*D): 140*40*146 mm (5.51*1.58*5.75")
Weight: 1.25 Kg (2.76 lbs)
Manufactured: Japan, 2004-200x (Discontinued)
Other: Digital voice/data option (UT-118 (frmr UT-115)) Please note that
this requires at least two similarly equipped radios.
207 memories. Weather channel with alert (US version only)
CTCSS, DTCS and DTMF. Multi-color LCD.
New price 2008 in Sweden: 3440:- SEK
Related documents: User manual (6.7 MB)
RX: 118-174 MHz
Mid1: 25 W
Mid2: 10 W
Lo: 5 W
1st IF: 21.7 MHz
2nd IF: 450 KHz
TX: Max 15 A
