Alan 42 whistling on channel 4 (PL)
- GusWroclaw
- Call Sign: 161TM313
Could I bother someone that owns an Alan 42 to switch to the Polish band (PL), remove fthe antenna, turn the squelch down and switch to channel 4? Do you hear a high pitched whistle? Additionally, if you go to channel 3, again without an antenna and put the squelch where it barely shuts off the speaker, and then switch to channel 4 ,does it open the speaker again because of this weird reception at channel 4? In other words does your Alan 42 also seem to be emitting internally something around channel 4 or is it just my radio? Is this normal or should I do something about it? It seems like a very faint signal so usually it's not an issue, but if I want to scan for very faint signals this thing halts my scan on channel 4.
161-TM-313 - Midland Alan 42
Re: Alan 42 whistling on channel 4 (PL)
Hi Gus
I remember having a older Alan 42 multi model and it did similar thing,I suspect your picking up internal "birdies" from the Micro processor Crystal 4.0 mhz or 4.30 mhz (depending on model version)and its multiplying a harmonic straight on that frequency 26.960Mhz ch3
service manual here http://www.cbradio.nl/alan/ServiceManua ... _Multi.pdf
Maybe ground the crystal to earth plane of pcb maybe reduce it?
I have done that,or adding a copper shield around microprocessor and bonding it to ground internally.
Im unsure if Midland\Alan spray the plastic case internally with special RFI paint to reduce case radiation?
I sent mine back to supplier as wasn't happy with them and annoying birdies in end and same issue scanning would stop all the time.
This is the RF paint ive used on plastic cases to help reduce EMI,RFI issues on cb handhelds with plastic cases.
https://uk.rs-online.com/web/p/shieldin ... s/0568483/
Also without proper test gear it maybe not so easy to track down problem.
Ive ended up with the President Randy II and haven't looked back in build quality and performance and none of these issues.
I know that doesn't help your issue and can relate to your frustrating problem.
I will assume you tried handheld in a different location to rule out strong computer,wifi,power supply local issues?
I cant see that ,but have to ask?
Regards Rob
Regards Rob
- lambrettadave
- Call Sign: TM455
I will check my Moonraker major 42 as they are quite similar to the midland 42
I've got a Midland 42 and don't even know how to get anything other than EU/UK.
- lambrettadave
- Call Sign: TM455
Dose yours have a am/FM button or a eu/UK button?
Hi have to hold down the LCR button to switch between EU/UK, that's all I know.
- GusWroclaw
Good catch, It's definitelly in channel 4 for me though, not on channel 3. And channel 4 in the Polish band is 27MHz exactly. So if the chip frequency was close to 4.5MHz, it could it be it. But with 4.3MHz it should have a harmonic at 25.8MHz. Unless you mean that what I hear is the product of the CPU clock modulating another signal in the radio. That could be it.rpcomms wrote: ↑20 Nov 2018, 23:48 Hi Gus
Well I'm thinking of opening it up and spraying it to see if it helps to be honest. I doubt I'll need the warranty anyway, seems quite sturdy and simply made to crap out on it's own. :-)rpcomms wrote: ↑20 Nov 2018, 23:48
Yeah the issue happens whether I am in a car, in my house or out in a field. With or without antenna. Pretty sure with any kind of battery as well. The only place where I haven't noticed the sound is in some corners of my house where the electrical noise is was stronger than the whistling signal sorpcomms wrote: ↑20 Nov 2018, 23:48
my ear doesn't pick it up, and the scanner doesn't stop on it either.
Thanks for the answer! I just realized that you people had replied here, I don't know how I missed the notifications. I'll read and reply to the rest in a few minutes.
- GusWroclaw
In mine I need to hold both LCR and SC (scan) down while turning on the radio. Then press the up arrow button on the side of the radio to select PL. But you probably have a different model.The Collector wrote: ↑21 Nov 2018, 21:08 Hi have to hold down the LCR button to switch between EU/UK, that's all I know.
- 163TM847
On my Alan 42 I am getting same thing but a dead carrier which is lighting one bar on s-meter rather than a whistleGusWroclaw wrote: ↑18 Nov 2018, 13:47 Could I bother someone that owns an Alan 42 to switch to the Polish band (PL), remove fthe antenna, turn the squelch down and switch to channel 4? Do you hear a high pitched whistle? Additionally, if you go to channel 3, again without an antenna and put the squelch where it barely shuts off the speaker, and then switch to channel 4 ,does it open the speaker again because of this weird reception at channel 4? In other words does your Alan 42 also seem to be emitting internally something around channel 4 or is it just my radio? Is this normal or should I do something about it? It seems like a very faint signal so usually it's not an issue, but if I want to scan for very faint signals this thing halts my scan on channel 4.
- 163TM847
With mine when its on UK i can hold down LCR to switch to EC/UK but with radio off if i hold down LCR and SC then power radio on i can let go of the LCR/SC buttons and use UP/DWN to select countries and then press LCR to select the country.The Collector wrote: ↑21 Nov 2018, 21:08 Hi have to hold down the LCR button to switch between EU/UK, that's all I know.
Handy to know, cheers Nick.
I only ever use it to test the radios I buy, as there's no bugger round here to get a rig-check off.
- GusWroclaw
Sounds like in your radio its exactly at the carrier frequency while in mine it's probably a bit off? Though it's not SSB... so I'm not sure how a single frequency a bit off carrier would sound, would it sound like a whistle? Or would the radio be unable to make any sound out of it without a carrier as well?Black Spirit wrote: ↑23 Nov 2018, 16:03 On my Alan 42 I am getting same thing but a dead carrier which is lighting one bar on s-meter rather than a whistle
EDIT: In mine it doesn't light up any bars in the s-meter.
OK best of luck fixing it
You could try and be very careful build a copper tin shield around xtall \microprocessor and solder a short ground wire
On underside use clear tape to insulate
it may help shielding anything from micro or harmonics of CPU xtal
I would suggest earthing the xtal to ground but without a frequency counter it may shift its frequency without you knowing.
If spraying RFI paint just ensure the PCB component parts dont come in contact with the case as they will short to ground,Boom!
You can ground the case via the plastic pcb screw in pillars,thats fine.
If all else fails well and need that band upgrade HT to Randy II or New Randy III soon.
Depends on personal OCD and radio if want things perfect
All the best
Rob 73's
All the best
Rob 73's
- GusWroclaw
Thanks for the tips Rob.
First I want to try and make an antenna. I got almost everything but I've been waiting for a more than a month now for some BNC adapters to arrive... I should find a shop here that sells these things. Once I try it out with an antenna I'll see about fiddling with the radio. I don't want to break it before that.
- 13EL121
- Call Sign: 13DA121
The Albrecht 2990AFS also has a birdy on 26.995 (CH 3A). Comes from the CPU xtal as expected.
Affects Albrecht 5890 EU as well. Same Family as Midland Radios, maybe same board and CPU design?
