Stalker 9 serial numbers
- prettypolly
- Call Sign: 26FB185
Can you tell how old a stalker 9 is by its serial number ??
- Otter
- Call Sign: 26TM439
Re: Stalker 9 serial numbers
What are the first 3 digits of the serial number?
- prettypolly
03004920
- Otter
Made in 1980 in Taiwan. That's not one of the ones with UK channels then because it's too early.
- Crusader
The one with the UK 40 muppets + mid & high bands was the 9FDX, the one that was FM/AM/SSB mid & high band was the 9DX & the one that was just AM/SSB (again mid & high bands) was the plain & simple Stalker 9,so we could do with knowing exactly which Stalker 9 he has.
- prettypolly
No FM just am ,USB, lsb
- Crusader
Thats the Stalker 9 then,so not a 9DX or 9FDX model,still a quality reliable rig,had a few over the years
Can anybody give me some info on the stalker with the serial number 03000557
will it cover the uk FM ? etc etc
any help would be great thanks
I can tell you that it was made in 1980 in Taiwan . Think you'll need to open it up and post some photos to see if it's been modded for the UK40 band .Traindriver1234 wrote: ↑06 Dec 2020, 15:44 Can anybody give me some info on the stalker with the serial number 03000557
ok will do many thanks
I've got 03003721 here, AM/SSB only. Cracking radios in their day and strangely one radio that doesn't seem to divide opinion I.e pretty much everyone accepted they were decent.
I worked the world in the early 90s on an 9 FDX and a bremi BRL200 amp. I cant find this radio now but if I do I'll post up the serial.
- 13EL121
- Call Sign: 13DA121
All Stalker 9 with FM and PC-893 PCB I had started with 13... serial number. Should be the same with the ST9 FDX.
just had a look inside
can anyone tell me if it has been modified ?
https://ibb.co/tcbxdPn
https://ibb.co/g96QZS7
it is just the am ssb version no fm fitted as far as i can tell
the block of crystals has a number uni fl-065
reason i am asking is there is a hold drilled in the back of the unit
nothing fitted just a piece of tape covering the hole
You've just started a new thread asking this same question . The crystal filer is standard .Traindriver1234 wrote: ↑08 Jan 2021, 16:05 just had a look inside
ok i will remove thos one sorry i did not know what section
so it is box standard
no mods at all
no mods at all
