Page 1 of 2
Silver Rod Question........
Posted: 19 Dec 2015, 17:00
by GBHgpJON
Should I be getting continuity across the chasis socket on the above antenna, I would have thought this indicates an internal short? Bit of a newb when it comes to base antennas!
Re: Silver Rod Question........
Posted: 19 Dec 2015, 17:12
by Mitch
It's a short circuit at DC but at RF frequencies it's not, they've got a coil inside (like an unun), an RF transformer to match impedance and one side of that is grounded.
Posted: 19 Dec 2015, 17:16
by GBHgpJON
Right, it seems I may have been a bit premature in taking it down, after checking the coax for shorts while the coax was still connected to the antenna!
Back up the ladder tomorrow then!........Thanks for the info, still learning stuff.
Posted: 19 Dec 2015, 21:52
by Dragonfly
Loosen and retighten the screw that goes through the bottom antenna section into the top of the coil as this is usually the first thing to carode and go high resistance .
Posted: 19 Dec 2015, 22:06
by ROTEL240
GBHgpJON wrote:Should I be getting continuity across the chasis socket on the above antenna, I would have thought this indicates an internal short? Bit of a newb when it comes to base antennas!
Yes its normal, your coax or plugs seen to be at fault mate...
Posted: 19 Dec 2015, 22:08
by Admiral
Obvious question, but what's the VSWR like?
Posted: 19 Dec 2015, 22:21
by superstar
yes i know i'm a bit of a cb anorak, but its only a silver rod if its the genuine telex hygain silver rod from the 70's, none of this flimsy modern stuff is worthy of the name, yes its silver, yes its a rod but is it a telex hygain silver rod? naaa lol
Posted: 20 Dec 2015, 00:08
by GBHgpJON
Admiral wrote:Obvious question, but what's the VSWR like?
Never got that far, I'd just soldered the pl259 onto the end of the coax, and checked continuity, only to get a short. Disconnected the antenna and didn't have short, then checked antenna only to find continuity/short and wrongly assumed the problem was with the antenna.......shame I didnt ask on here before taking it down
.........bottom self tapper should be ok as its brand new.
It sez Silver Rod on the box.....thats good enough for me........
Posted: 20 Dec 2015, 09:56
by Mudslinger
If you have a DC short with the coax connected but not without then it sounds to me like everything is ok...
Posted: 20 Dec 2015, 13:22
by Oggy
superstar wrote:yes i know i'm a bit of a cb anorak, but its only a silver rod if its the genuine telex hygain silver rod from the 70's, none of this flimsy modern stuff is worthy of the name, yes its silver, yes its a rod but is it a telex hygain silver rod? naaa lol
Your as bad as me
Posted: 20 Dec 2015, 14:03
by Mudslinger
The only "Silver rod" worth buying now is the Sirio one.
The rest are just flimsy rubbish.
Posted: 21 Dec 2015, 12:35
by GBHgpJON
Up and running now,
SWR is 1.5:1 to 1.7:1 out of the box ....performance seems about the same as the inverted v in the loft, the (ahem) Silver Rods tip is bout 2m higher. Once the neighbours get used to the outside antenna I'll start to raise it up.
Not much local stuff around anyway, so I may just stick with the v in the loft......time will tell
Cheers for the help.
Posted: 21 Dec 2015, 14:44
by The Collector
Every extra foot up will pull more stuff in, so get hoiking
Posted: 21 Dec 2015, 15:36
by GBHgpJON
Was gonna use the hoik word, but I reckoned people would be like....eh??
Now picking some local stuff that the v aint getting, so its looking hopeful!
Posted: 10 Jun 2018, 11:28
by superstar
here’s a real one
