There are two different varieties of DP3600.. -
UHF 1 - 403-470 MHz (UHF1)
UHF 2 - 450-512 MHz (UHF2)
Anyone know how to work out which is which?
I have found two model numbers -
MDH55QDH9JA1AN
MDH55QDH9JA1AN2
I would guess the latter is UHF2 but I would really like to know for sure.
DP3600 Model Identification
- radiogaga
- Call Sign: 26TM399
30TM399 Northern Costa Blanca
Re: DP3600 Model Identification
Any ones I have had are 403-470 and do not have the 2 at the end of the model number.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- AshtonMobileScanner
- Call Sign: 26TM931
Ive typed the model number MDH55QDH9JA1AN2 into google and it brings the 136-174MHz DP3600 or the 403-470MHz DP3600
Motorola UHF DP3600,
Golden One 1907,
Baofeng UV5RA+,
Diamond RH771 Antenna,
UHF Stubby Antenna,
Diamond X-30 Antenna,
MASS SPS 250 MK2.
(Monitor All Channels)
- wheelbarrow
MDH55JDH9JA1_N DP 3600 VHF *
MDH55JDH9JA2_N DP 3600 VHF (20kHz)**
MDH55QDH9JA1_N DP 3600 UHF1
MDH55TDH9JA1_N DP 3600 UHF2 *
VHF (136-174MHz); UHF1 (403-470MHz); UHF2 (450-512MHz)
Here's how the model number coding works:
- radiogaga
Perfect - Thanks chaps!
