Page 1 of 1
Yaesu VR500 display.. Random pixels missing?
Posted: 19 Jul 2013, 16:26
by Squelch
Anyone got one of these radios and had a similar problem?
Most of the time I switch on lately, over the last few months various bits of numbers and letters are missing form the display. Some times it's worse than others.
Re: Yaesu VR500 display.. Random pixels missing?
Posted: 22 Jul 2013, 19:50
by kurisu
do you have a picture?
Posted: 22 Jul 2013, 22:36
by kr0ne
Sounds like a dodgy connection to the display to me...
Having said that, I have a VR500 and I do get what is almost a missing line when I first switch it on as the batteries start to die, but you can see the missing pixels if you hold it at just the right angle.
Posted: 21 Apr 2014, 18:05
by Squelch
I know it's a while since I mentioned this but not been using the radio much until recently. The display is virtually unreadable now , although the reception is fine on the audio side . What I have noticed though is when left it in the sun or in a warm conservatory for instance the display is almost perfect ,although it does still have an odd one or two pixels missing , the colder it is the worse the display.
Does this seem like a component failure which needs replacement or could there be a repair? I have had the back open but there's no obvious loose connections .
Posted: 26 Oct 2018, 19:24
by mw0uzo
I dug my VR500 out of a drawer after about 10 years. The screen was barely working, I think I threw it in there in disgust when the problem got really bad. This thread was the top search result. Here is how I fixed it. Difficulty moderate, SMT hot air station required.
http://mw0uzo.co.uk/index.php/8-repairs ... isplay-fix
Posted: 04 Dec 2018, 19:25
by Squelch
That's useful info, thank you ,
It's about 4 years since I posted this originally and just happened to drop in now . The display is still as bad as it was but I noticed it's a lot worse when the radio is cold. I have stripped it down but could not see how to get at the display under the cover . This explains it nicely and where the problem lies . so I'll have a go at it at some point soon .
