Greetings,
Came back to work today after Friday off, and found my Uniden UBC 3500XLT had arrived in my absence. Without further ado, I take it out of the box and have a quick dabble while stood in Work's car park while on my afternoon break.
I discovered this frequency: 453.850mhz NFM
The conversation appeared to be council workers, or some form of inspectors of some form. As they mentioned a car that had ran out of tax that someone on foot had discovered. If you live immediately around a couple of miles around the M58, you will probably locate it very strongly.
Upto now, this scanner is damn cool and near idiot proof to use compared to my Yupiteru MVT9000. The menu system reminds me of MP3 players for some odd reason.
Inspectors on 453.850mhz NFM located when on work break!
- Panteneman
Speaking to people in foreign lands, with various configurations of copper wire in various strange shapes - my friends think I'm committing acts of witchcraft...
- 5thElement
RE: Inspectors on 453.850mhz NFM located when on work break
That's what i've described the 3500xlt "operating system" like before, like an mp3 player, everything clearly labelled in the menus, really nice radio to use, im glad you seem to be enjoying it I turned on the 72xlt today after not using it for months and jeez, it seems so backwards it's unreal compared to the 3500 lol really miss the menu's and alpha tags and ctcss decoding!
I dont suppose you got a ctcss for this user? in the menus you can set it to decode ctcss for everything (sure you've worked that out allready though)
2E0XGA
- Panteneman
No,
Signal was only RST 335 or thereabouts, and I only just took it out the box and went outside in the car park to try it out.
Going to program more channels into it via the software, as I have BCTool and the serial cable.
- 5thElement
Cool, i don't have the serial cable for mine yet, tbh i've found programming by it hand pretty easy, maybe a little tedious at first when i had a stack to put in, but it's not difficult. The software would be pretty good though for rearranging things and putting in large groups of channels, ie the 80 cb channels and so on, i believe the radio can also be controlled via the software which would be pretty handy when your sat at home using it on an external antenna while on the computer, hmm, i might just have to invest in one!
I assume your first impressions are good?
2E0XGA
