After 2 years of using my Midland Alan 78 Plus Multi, I got another CB from eBay a Danita 3000, this was very easy to mod to get the 400 channels, now after a long haul I finaly found how to mod the Midland 78+ a lot of users of this radio out there find they try the 2 link way and it still dont work.
I have added an attachment to show you how its done.
The only reason I done it for both was that here where I live there are music players, dead keyers, total foul mouth and not much as in the way of any sort of Inteligent chat.
So me and a few trusted others go to the lower blocks to get the so called Inteligent chat, it gets us away from well shall we say the idiots on CH19.
Perhaps you simply don't want to do the mod well thats fine but for my reason it works and works well, we dont go for DX but local work for each other.
Mike.
400 channel
400 channel
Re: 400 channel
That's cool Mike, it would be even cooler if it was in English.
Re: 400 channel
Ok just for you then
APERTO = OPEN
CHIUSO = CLOSED
PONTICELLO = BRIDGE
So its....
Ponticello/Bridge JP0 Aperto/Open
Ponticello/Bridge JP1 Chiuso/Closed
The rest of it is.....
Then turn off Radio, then press both AM/FM and Scan at the same time, then choose RU, then press AM/FM to get the RU (Russian) block of 400 channels.
25.615 Mhz - 30.105 Mhz
And away you go.
Mike.
APERTO = OPEN
CHIUSO = CLOSED
PONTICELLO = BRIDGE
So its....
And away you go.
Mike.
- Call Sign: 26TM1305
Re: 400 channel
For anybody still interested in this mod that happens to have the newer model of the radio with the blue display check the attached pdf. OPT1 and OPT3 are the ones you want bridged leaving OPT2 open.
It can be a bit fiddly if you are not great at soldering as the solder points are pretty small and on the 2 sets that I have modded OPT2 and OPT3 were all bridged with one almighty blob of solder from the factory so I had to remove that with some desolder braid first, leave OPT2 open and then rebridge OPT3.
Out of the factory all three were bridged with 2 and 3 bridged together (presumably this was deliberate as it was the same on 2 radios that I worked on).
26-TM-1305
Re: 400 channel
But the board is not the same the 3 points mention does not exist and the ic BU2630F is done upside down.
Re: 400 channel
And please can you tell me the 2 points marked with ink on the diagram what they mean?
