I have just been given an Amstrad 901. It looks as if it has been well used & come with no power cable.
So does anyone know if it's still possible to acquire the power leads for these or is it a hard wireing job ?
Amstrad 901.
Amstrad 901.
So I passed this test that allows me to twiddle with knobs, push buttons & call my self an Advanced !!!!!!!
M0LSX
M0LSX
- ScotchEgg
- Call Sign: 26TM742
RE: Amstrad 901.
I think its the standard 2 pin type as used on Han Int etc, iirc.
Have gander on ebat they are cheap enuf.
The legend of the "Scotch Egg".
"unique in my duplicity"
UGLY BOB on SCOTCH EGG... "I kinda had you pictured as the sort who would enjoy beating the bejesus out of people with a four foot dildo."
- CaptainKirk
- Call Sign: KIRKY
RE: Amstrad 901.
the amstrad i had the power socket was different than the cybernet it was more like the old midland/maxcom type but smaller
CAPTAIN KIRK-26TM013/26CT013/26UK013 John mobile South Cheshire.
I have just had a look on the Knights site & there is a Amstrad connector which has one square & one round pin & this is not one of them.
But it is very small, like the one shown.
I tried the Ham Int power lead on the Amsttrad & although it was VERY loose, it did work sort of, but I am not sure I want to sit & hold it in place so I will try & either find a correct lead or a way of fitting the Ham Int lead more firmly.
The rig worked fine on RX. I only have the CP6 HF antenna & it was slightlyoff it's 10 meter band down there. But with the MFJ tuner exstender I got the SWR right doen to just below 2:1 on channels 1 through 20 & then as low as 1.2:1 on channel 40.
Power out put showed as around 4.25 watts. The volume control is a little noisy, but I'm told the rig has been in the loft for 20 plus years so I'm sure a drop of switch cleaner will sort that out.
Not bad for another Freecycle freebie.
M0LSX
M0LSX
