Im looking for the mod to replace the mb8719 with the mc145106pll.
I have seen some where you keep the 8719 for filtering.
Is the 1 mod where you shift all the pins 9-17 on the mc145106pll and grnd pin 6 with pin 17 going to ground with a resistor and then to 5+volts.
will this mod work and get the regular 40 and then some uppers and lowers?
Im trying to do this by replacing the mb8719 just using the mc145106.
Can someone let me know if this will work on a Washington base?
Doing this mod will it still get regular and high low channels?
thanks
mb8719 replace with the mc145106 pll
- cb4ever104
Re: mb8719 replace with the mc145106 pll
There are dedicated stand alone modules now for the 8719 that will give you all 3 bands plus the UK and +5 and +10 . Makes life a lot easier , and they're easily removed if the radio needs to b put back to stock .
http://funkservice.at/en_pll-modul.htm
https://www.microchipz.net/uniden
I was kinda looking to do this myself without buying any modules I have read there are many mods but seem to be incomplete in the diagram.
thanks for the info
thanks for the info
