Hi all..
Galaxy Fc 347 the Later (Blue) type, I’d like to change out the Blue 7 segment LEDs for Red, struggling to find the Specs of the Blue LEDs, Part Numbers on the Blues are XIN-DD104B01-04, Anyone ever done this and have a reference to the correct pin outs in Red? I know this was fairly easily done with the green LED type counters however they used a different LED I believe ..
Galaxy FC-347/CRT KF-VI Frequency counter..
- Raverrst
- Call Sign: 26LW29
Radios, radio!!
- Call Sign: Lemmy
Re: Galaxy FC-347/CRT KF-VI Frequency counter..
Single digit 0.3" led display with common anode.
- Raverrst
- Call Sign: 26LW29
Problem I’m having is there’s seems to be different pin-outs, from the little I can find about the Blues fitted the common is pin 1, anything I’m finding in Red the common is pins 3 & 14 .. really need to find the specs for the Blues currently fitted
Radios, radio!!
- Mitch
- Call Sign: M1TCH
Can you buzz out the pins? An old style analogue multimeter on the Resistance x1 range is usually enough to light the digits, you could map the pinouts to compare with what's available.
The perfect face for radio.
- Raverrst
- Call Sign: 26LW29
That’s agood idea, I will Endeavour to do this when time allows. Tho Wish I could just find the specs on-line or better still find someone who has replaced the LEDs with Reds and knows the replacements required..
Radios, radio!!
- Mitch
- Call Sign: M1TCH
I like the green one myself, which I have, all I changed on mine was the front plastic glass, original was scratched. I'd have a green readout in the radio too if I could get the green cover, maybe one day, it doesn't look so bad though...
- Raverrst
- Call Sign: 26LW29
I would definitely prefer the green to the blue, plus they’re much easier to modify to red if required. Trouble is there all getting harder to come by and silly money when they do come up..
Radios, radio!!
