Antenna Advice
damhug1980
Antenna Advice
Post by damhug1980 »
Hi All
I am just starting out on CB and I have magmount with a Sirio 900 blue line antenna, I have tried to use it indoors but not picking up a lot. I was thinking of getting a grounded mirror mount antenna kit and attaching it the pole of my old sky dish, would this work or would I better getting a different homebase antenna?
Damian
Re: Antenna Advice
Post by ch25 »
damhug1980
Re: Antenna Advice
ch25 wrote: 03 Oct 2023, 08:58 That's a minimum https://www.thunderpole.co.uk/base-cb-a ... -wave.html
Thanks for your reply, can I bolt this to my sky dish pole or need to bolt it to the wall?
Re: Antenna Advice
Post by ch25 »
To dish pole.
Keep in mind, that it should be in a free space. Closer to obstacles, worst performance.
If you will have for example building wall along antenna performance will be poor and you will have SWR problems.
Re: Antenna Advice
Post by The Collector »
Perhaps try the radio and magmount in a car on high ground locally for an hour or so for a few evenings, especially the weekend. If you still can't hear anyone at all, even distant, I'd save your money as you might not have anyone living close enough to talk to, even with a bigger, expensive homebase aerial.
damhug1980
Re: Antenna Advice
Hi, I managed to get the Silver rod installed on my sky dish pole and the SWR reading on the radio CRT 6900N is coming through as 1.0/1.1 but some of the voices coming through sound distorted, anyone able to advise on this?
Re: Antenna Advice
Post by ch25 »
Record and post that distortion so we could hear that.
108AW027
Call Sign: 108TM119
Re: Antenna Advice
Post by 108AW027 »
damhug1980 wrote: 20 Oct 2023, 12:08 Hi, I managed to get the Silver rod installed on my sky dish pole and the SWR reading on the radio CRT 6900N is coming through as 1.0/1.1 but some of the voices coming through sound distorted, anyone able to advise on this?
Are you on AM/ FM /USB or LSB when the voices are distorted ?
108 FB 027--108 TM 119
damhug1980
Re: Antenna Advice
Hi, It is mostly on USB and LSB?
damhug1980
Re: Antenna Advice
ch25 wrote: 20 Oct 2023, 12:19 Record and post that distortion so we could hear that.
Here is an audio file from USB
Tin soldier
Re: Antenna Advice
Post by Tin soldier »
Tune it in with the clarifier.
They are clicky and sound goes off with each click on the 6900's .
So a bit of a pain.
damhug1980
Re: Antenna Advice
Tin soldier wrote: 20 Oct 2023, 14:14 Tune it in with the clarifier.
So a bit of a pain.
Thanks, I will try the clarifier later on this evening.
Tin soldier
Re: Antenna Advice
damhug1980 wrote: 20 Oct 2023, 14:20
So a bit of a pain.
damhug1980
Re: Antenna Advice
Hi, my radio is starting to make this noise on most stations, is it something to be worried about or is it normal?
Buick Mackane
Moderator
Moderator
Re: Antenna Advice
Post by Buick Mackane »
damhug1980 wrote: 25 Oct 2023, 08:17 Hi, my radio is starting to make this noise on most stations, is it something to be worried about or is it normal?
Turn off the mains supply in your house and power your radio from a battery (if you have one) and see if the noise persists or not
