Ubitx Relay Upgrade which type ?
Buick Mackane
Moderator
Moderator
Post by Buick Mackane »
I have an early version of this radio and need to swap out the bandpass switching relays as the stock ones cause problems with harmonics, Iv'e read that the type to use are Axicom D2n 12v relays ((model V23105-A5403-A201)
I Can't find that type but iv'e came across a similar type, Anybody know if these would be suitable ?
https://www.ebay.co.uk/itm/144300733609 ... R-zawdf7YA
108AW027
Call Sign: 108TM119
Re: Ubitx Relay Upgrade which type ?
Post by 108AW027 »
108 FB 027--108 TM 119
Buick Mackane
Moderator
Moderator
Yeah, But trying to keep the cost down hence the ones in my ebay link, The spec seems to check out but don't wanna buy them just incase they aren't suitable
108AW027
Call Sign: 108TM119
Post by 108AW027 »
ok,,it was just you wrote in your post that you could not find that type.
Buick Mackane
Moderator
Moderator
108AW027 wrote: 16 Oct 2022, 10:28 ok,,it was just you wrote in your post that you could not find that type.
Meant that i couldn't find them on ebay which is the only place i shop online, Cheers anyway pal :thumbup:
Buick Mackane
Moderator
Moderator
I bought them as the spec is very similar to the recommended ones, Was under a fiver for five of them so won't end up bankrupt if they turn out not to be suitable, I'll report back after iv'e swapped them out..
Buick Mackane
Moderator
Moderator
Relays arrived this morning after a 12 day wait, I ordered 5 for £4.65, He sent 18 :lol: I swapped out the TX/RX Relay aswell, Didn't need to change it but not like i'm short of a relay or 18
Not had an on air contact yet but all looks good.
Buick Mackane
Moderator
Moderator
Made a few contacts, All working good..
