Hi all.
I don't know if this board with the 3 crystals on is normally found inside an Intek1200 / Lafayette1200 / Cobra150 SSB radio, but the adjustable wheel and 2 wires going to it through the cases is definitely not.
What do you think this could be for? Tweaking the TX frequencies, or more range on the RX in case the fine tune doesn't go far enough???:
What's this for?
What's this for?
Re: What's this for?
More including a pic of some components covered in masking tape on solder side, not connected to board or wheel though.
More
- 14CS06
Merci Claude. Is this to adjust RX or TX?
- 14CS06
Hello
Definitely RX and TX
Who is at the end of the 2 wires
Claude
Claude
This is what was on the other end of that wheel, through the casing:
- 14CS06
Hello
It is Condensateur Variable Capacitors
https://www.ebay.fr/itm/353929275083?ha ... Sw~bhcU~VQ
http://www.zpag.net/Electroniques/ConVarDes.htm
Claude
Claude
Oooo...thanks again Claude. I wonder what adjustment it gives one way/each way? It looks like I might have to take my Excalibur, co-ax and shelving apart to access my frequency counter that's wired up to it, just to find out what shift it allows.
