Hello all thank you for allowing me to be here
i have just scored a tait 2020 mk 11 2020-513 sn i think is 61908
i have a laptop windows xp with serial port and cable.
i have downloaded Tait 2000conventional app vers 3.00.00 the download is titled version 3.01
i can read the radio
modelT2020
SW version std 0502
DB version 0204
com port in device manager is com 1 and in software
when i try to read the radio it says "this is an unknown radio and cannot be read
HELP
cheers john
Tait 2020 mk11 programming
- Call Sign: 26DG01
Re: Tait 2020 mk11 programming
Is it a trunking radio? If so, you will need the trunking software.
Sent from my GP300 using DTMF
- New User
- Call Sign: vk5kj
well according to my investigations there isnt a 2020 mk11 trunking
john
john
- Call Sign: 26DG01
Try writing something to it, it might have got corrupted or there could be some kind of read lock. There is info on here about the T2020, although most of it relates to the type 1. It may benefit from a total reset, although I don't know if the same procedure applies to type 2.
Also, are you running the laptop plugged in to the charger? You may have a ground loop affecting the serial cable. Try running the laptop on the battery only, not plugged in. If the lappy won't run without the charger, try using a clean DC power feed to it, and the radio (a battery or something).
- Call Sign: DF2TB
John,
welcome to TM1. Not sure if it is of any help with your particular radio but I have the Windows SW for the T2000 radios. If you send an email to [email protected] I can provide you with it. At least it is worth a try I think.
Cheers Andreas DF2TB
- New User
- Call Sign: vk5kj
another question the software i am using at the bottom it says software version 0304 and when interrogating the radio it mentions
database version 0204
software version STD-0502
any clues what this means
Cheers John
Cheers John
