I have a Uniden PC66a that I'm currently working on, the speaker is toast, so I am looking for another one. The stock speaker is a 16 ohm 1 watt 3" speaker. Is there anywhere I can find these? All the 3" speakers I am coming across are 8 ohm, or too high of a wattage. I'm assuming that throwing an 8 ohm in would cause issues with a mismatch in impedance, and probably blow the speaker, putting me back to square one.
Is there anyone familiar with which pots do what adjustments for these? I cannot find the manual anywhere, and most of my searches turn up the PC66xl, which is not the same thing from what I can tell.
Uniden PC66a speaker (and other things?)
- Call Sign: K2MGY
- Call Sign: 26TM773
- Call Sign: K2MGY
Re: Uniden PC66a speaker (and other things?)
Sadly no, I should have mentioned it is a square mount.ChubbyChops wrote: ↑21 Dec 2021, 18:17 This any good ?
https://www.ebay.co.uk/itm/224661483860 ... SwiV9fYAr-
- 14CS06
Hello
The speaker is SP-227 16 OHMS 1WATT same as
Président Valery - Taylor - François - Jack
Uniden PC-33X - PC 43
Claude
Claude
- Call Sign: K2MGY
- Call Sign: K2MGY
Is there anywhere I can find information regarding mods to this radio? I've found a couple that only mention power/modulation increases via swapping components, but I am trying to find out about a .005 MHz shift. I was trying to chase down the reason the "Brite/Dim" button didn't appear to be doing anything, and found that it increases the static a bit and shifts .005 MHz down on every channel.
And while tying this, I decided to try something regarding the static, and have found that if the "ANL/NB" button is pressed, it gives me upper channels! This radio just seems to not want to be figured out!
- 14CS06
Hello
What is the board number
https://www.radiomods.co.nz/unidenpc66pc66a.html
http://www.mark-rodgers.com/2009/04/uni ... -mods.html
Claude
Claude
- Call Sign: K2MGY
These are the mods I come across everywhere I search. I'm trying to find information on what may have been done to the radio to allow it to have expanded frequencies. I can find nothing regarding the channel mods for this. I'm not trying to undo them, just trying to find out what would have been done so I can proceed with the rehabilitation of this radio.
14CS06 wrote: ↑31 Dec 2021, 10:27 Hello
Claude
- 14CS06
Hello
Hello
Claude
Hello
Claude
