Cobra 148GTL adding FM?
- Call Sign: 26TM2714
Hi,
Can FM be added to these...
If yes, Spectrum FM455?
And does anyone have a How2 or fitting instructions for it?
WANTED
Galaxy Pluto, 2100, DX88HL, President Ronald (Or Equivalent)
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
- cb4ever104
Re: Cobra 148GTL adding FM?
Edit : Spectrum say it can't be done . See below You get the fitting instructions when you buy the kit . Here's a copy of mine .
S.
Appreciate the super quick reply...cb4ever104 wrote: ↑09 May 2021, 15:16Yes , and yes . You get the fitting instructions when you buy the kit . Here's a copy of mine .
S.
Did you fit yours to a 148GTL specifically or another?
Thanks again!
WANTED
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
- cb4ever104
Edit . I fitted one in a Madison, but it wasn't fully tested . I have another one that I've built, but haven't fitted yet to my 148 GTL. I'll get round to it at the end of the year. I may put one in my 2000 GTL as well at some point.
I'll post if I get stuck, highly likely!cb4ever104 wrote: ↑09 May 2021, 16:31 I did one in my Madison, which is the same. I have another one that I've built, but haven't fitted yet to my 148 GTL. I'll get round to it at the end of the year. I may put one in my 2000 GTL as well at some point.
I'll have to see how hard it would be to put on the rotary switch with the AM,USB and LSB (apart from needing a 4 position switch)
WANTED
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
- cb4ever104
Edit : Actually that's something that I needed to look at too The Madison has a separate AM/FM switch It won't be that hard to do on the 148/2000. Maybe a 2 pole 4 way , or 3 pole. I'll need to draw it out first. All good fun
If you manage to draw it up would appreciate the info!cb4ever104 wrote: ↑09 May 2021, 18:37 Actually that's something that I needed to look at too I had a separate AM/FM switch on the Madison , so it was pretty straight forward. It won't be that hard to do on the 148/2000. Maybe a 2 pole 4 way , or 3 pole. I'll need to draw it out first. All good fun
I'll see if I can find a 148gtl schematic and have look!
EDIT~
http://www.cbtricks.com/radios/cobra/148gtl/index.htm
WANTED
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
- cb4ever104
Yeah . I won't be doing it till later in the year . I've got all the service info for the 148 GTL . I've just had a look . The existing mode switch is 3 pole . So , I'm pretty sure a 4 way 3 pole will suffice . However , I'll need to go through it . It might also be worth sending Tony an email at Spectrum as well , to see if he has any bits of advice . Also , the 148 GTL-DX wiring will also come in handy as we're ultimately going to end up with the same FM switch configuration . I don't have my radios here . I'll maybe try and draw something up using the schematics when I get a chance .
Funnily enough I'm just sending Tony a message via eBay now... Will see if he's in a knowledge giving mood or not... (Seems to be hit and miss which Tony you get from my experience!)cb4ever104 wrote: ↑09 May 2021, 19:26Yeah . I won't be doing it till later in the year . I've got all the service info for the 148 GTL . I've just had a look . The existing mode switch is 3 pole . So , I'm pretty sure a 4 way 3 pole will suffice . However , I'll need to go through it . It might also be worth sending Tony an email at Spectrum as well , to see if he has any bits of advice . Also , the 148 GTL-DX wiring will also come in handy as we're ultimately going to end up with the same FM switch configuration . I don't have my radios here . I'll maybe try and draw something up using the schematics when I get a chance .
I'll refresh the old brain matter regarding the DX wiring and see what I come up with too!
Thanks,
Peter.
WANTED
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
Well got a reply from Spectrum... Not what I was expecting though!
WANTED
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
- cb4ever104
Yikes. Sorry about that Peter . Looks as if I've given you wrong information . I thought it would have worked in the 148. Gerhard does one that's compatible with it though.
http://funkservice.at/en_fm-modul.htm
- cb4ever104
I have my doubts about that Madison now . I used one of their boards I had ripped out from another radio to replace a faulty FM one on that Madison . It was years ago , but I'm now doubting it it actually worked I fitted it , and I thought it sounded OK , but I didn't do much RX testing as we don't use FM much in Spain . I don't have that radio any more , so I can't check it . Saying that , Nick fitted one , so I'm not sure now .
Just in case I think I'll edit some of my previous comments , so as not to give incorrect information to other users .163TM847 wrote: ↑20 Mar 2015, 22:29 This one was a standard AM/SSB 40 channel but now has a Spectrum FM board fitted which i wired to a four way mode switch and also added the PIC to do High band/Uk40/+10kc.
Works really well but not quite finished as i need to find something to hide the outside of the counter display and tidy some wires up.
Hi Paul,cb4ever104 wrote: ↑10 May 2021, 07:33 Yikes. Sorry about that Peter . Looks as if I've given you wrong information . I thought it would have worked in the 148. Gerhard does one that's compatible with it though.
No problem, learn something new everyday...
I'll drop Gerhard a message and check with him...
PCB FM-Module 7.8 MHz
Price: EUR 45
Appreciate the info and pointing me in the right direction!
WANTED
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
- cb4ever104
No problem Peter . I need to do some checking on that Spectrum module myself , as I'm still not 100% clear on a few things .
Gerhard's modules are great , but they're not cheap . Postage is currently €15 . So that's €60 just to add FM . Anyway , let me know if you buy one , as I've never tried them .
Cheers
Yep, Its a big jump from £15 to 60 euros (£52)cb4ever104 wrote: ↑10 May 2021, 10:19No problem Peter . I need to do some checking on that Spectrum module myself , as I'm still not 100% clear on a few things .
Cheers
I may give this one a miss, got plenty of rigs to get FM...
Another option for the 148GTL is a DDS VFO kit!
Thanks again!
Peter.
WANTED
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
