crt space power setting ?
- WARLOCK
- Call Sign: 26TM134
i have a CRT SPACE U radio when i have a go at setting the output power to H it is ok untill i change channel it gos back to L so do i have to enter the H setting some way ???
- Buick Mackane
Re: crt space power setting ?
How about thanking mikel from your previous thread first ? You seem to have developed a habit of posting threads then not replying to them,
Good manners cost nothing.
I bet it's described somewhere in the manual.
- Kaos
- WARLOCK
I wish i was as clever as you guys but i am not and this is why i ask questions on here , one is telling me it is in the manual well i have the manual AND i cant find the answer to my question another is telling me google has the answer which i cannot find the answer to my question on google maybe they could PLEASE be so kind and tell me the answer to my question OR maybe they dont know it ??? are they as clever as they think ,I THANK THEM IN ADVANCE FOR THERE HELP IF IT IS COMMING
Someone programmed that channel to have LO by default. Use PC programming software to change that.
- WARLOCK
THANKS CHRIS, now just waiting for KAOS to tell me how i am going to sort my problem as he found the answer to my problem on googe which i could not find ???
According to the manual H is the default setting.
Was it a new radio ? maybe a factory reset and start again.
- WARLOCK
THANKS ALAN ,yes it is a new radio that had the PMR446 16 frequencies loaded so if i can help i do not want to do a reset as i think i would loose the 16 pmr channels ,
- Mikel
Yes, and I know who you bought it off and that's why it is messed up
- WARLOCK
Would that be from CORNWALL ??? how did you guess, never again , do you know if i was to reset would i loose the 16 channels or maybe that would be better in the long run anyway ,i can set the channel to H through the menue but when i change the channel gos back to L, maybe i will learn one day ,if so i had better be quick as i am 75 ????
- Mikel
Yes that is the dealer! He has probably set the radio at low power intentionally, so that they are less likely to go back to him faulty. He is cheap, but does not have a good reputation for after sales support.
No.20 function menu is reset, If you reset you will lose the channels
The programming software is available to download:
https://simonthewizard.com/2018/11/16/m ... space-u-v/
You will need a programming cable.
I haven’t read the whole manual but you should be able to set the memory channels without the programming software?
You should have stuck with your Yaesu 897
- LeakyFeeder
Ahhh the 'dealer' in Cornwall.....
- Mikel
- Tin soldier
Stumbled across this thread funnily enough after reading about the Cornwall dealer on another thread.
Anyway, one thing led to another and the fact my CRT space U resets to medium power.
I don't use it often but did notice last week when a long distance contact mentioned my signal and audio had suddenly dropped. (Think changing channels).
This was purchased new and programmed for PMR from a different very reputable dealer.
(And I'm not inferring anything regarding reputation of the Cornwall dealer here)
But wonder whether the CRT space U may incur heat damage on constant full power so this setting is made as a precaution. ?
I might fire it up today/tonight and see what's going on.
I too did a Google search but unlike was mentioned, the only thing that came up was this thread
If programming is the only option then I might leave as is. Bit of a faff but hey ho.
I haven't a lead (unless the Baofeng one will work ???.
Although I wouldn't mind reprogramming it to open it up.
