hf antenna which ?
- WARLOCK
- Call Sign: 26TM134
hf antenna which ?
Hi all , having been told by council to take down my antennas ,From what I understand they will turn a blind eye to a single wire type antenna any thoughts as to what I should put up to keep the peace ? Would you go for 20mt or 40mt ?
- Call Sign: M0AFJ
Re: hf antenna which ?
As long a length of wire you can put up, centre fed with 450 Ohm twin into the balanced terminals on your ATU.
