Bought a old original k40 today. It apparently had the boot lip fitment and not mag mount base I had decades ago.
So I get home to realise it's not even complete for the boot lip as the chrome piece and the actual u kind of bracket are both missing.
Basically I have the whip the and top piece and the lower black plastic part the top couples on too.
Both u bracket and chrome lower piece missing.
I have a old mag mount base sirio style and I have been racking my brains to try think how if I could fit the lower black piece to it somehow.
I don't think it would be v cost effective to try buy new replacements to mag base it unless I can find a complete mag base used or sale eventually .
If anyone has mounted such to a mag base or may have a idea how yo modify with what I have I'd appreciate the thoughts or info.
That will teach me to impulse buy .
K40 mount help
Re: K40 mount help
Give Knights a phone as you never know,maybe have the bits you need
27.555 Usb
27.555 Usb
- Call Sign: 45
Re: K40 mount help
I will make a few calls as I have found online you can buy the mag base complete however it still is missing the mounting that forms part of the chrome swivel part.
I think it will make it a UN economical repair if I'm honest.
But as a last resort.
I have saved a few Google searches in case a complete mag base comes up used also ,May be a consideration.
Will try all the same , be nice to keep it original but if I can utilise it on a diff mag base that would be fine too.
Thank you
- 14CS06
Re: K40 mount help
You may be able to use a magmountcwith a taller centre profile so you can fit bolts, washers etc to hold the plastic dome in place.
This is my Tagra t40 base which is similar, but not identical to the K40's:
- Call Sign: 45
Re: K40 mount help
Thank you gents have been contacted re a mounting bracket for the antenna.
So I now will have the missing rotation mount chrome.
Just need a mag base now to compliment it or as suggested utilise bolt washers so on on a talker mag base maybe.I think though a correct mag base would be better.
Loved my k40 back in the day.
Be nice to compare it to sirios so on once together
Getting somewhere.
Thank you all
Getting somewhere.
Thank you all
Re: K40 mount help
It should give a decent signal, but shouldn't be as good as a Sirio 4000/5000 unless something's not set up right.
I had a really old one (about 1979 with the lettering completely worn off)) that did the job back then for a year or two and I only sold it a few years back. I never fully trusted the mount though as it seemed to want to twist off too easily (big thin 1/2 mm firm rubber washer helped).
- Call Sign: 45
Re: K40 mount help
I suspected that it wouldn't perform quite as good as the sirio.I have a 3000/4000 and a 5' f stick 2 that I would like to test the k40 against .
I'm amazed this k40 has the original pl plug too with unmarked coax .
But yes I remember mine back I the day being of a easy twist off.
If this one is I will use the rubber washer trick.
I still kept a kick out of buying equipment that needs TLC ,cosmetically I love it but I'm not at all great with radio guts
It was nice to meet the original owner I bought it off too ,hearing his stories from the radio era .
Re: K40 mount help
I found them to be a bit "whippy" as they use a parallel whip and not a tapered one like my t40. It used to bounce around a lot more than later aerials I used because of this and others would say my signal used to go up and down from 30+ to 5 whilst whizzing around rat runs.
It was more stable signal-wise at a constant speed on motorways etc.
