London Bus change over to DMR
- Metradio
- Call Sign: G7HID
Testing of the London Bus DMR Network has started. From where I live I am receiving DMR in the clear from them on 139.66875MHz, this has been receivable for the last 3 weeks or so. Eventualy the system will be encrypted.
Their current MPT1327 and the new DMR Tier III system use the frequencies between 139.500 and 140.500MHz..
Mike
http://www.landmobile.co.uk/news/tait-t ... act-award/
Mike
Re: London Bus change over to DMR
Does this testing and upcoming change explain why I can now hear drivers on the 1to1 calls? In the past I could only hear the controller during 1to1 calls but on on group calls I could hear all drivers on the route. Now I can hear both sides all the time.
- Metradio
- Call Sign: G7HID
Yes I think it does...
Mike
Mike
- radiosification
I'm rather disappointed, I can't hear the new DMR system still
- Metradio
- Call Sign: G7HID
From Slough I can only pick up the one frequency, but a listener East of London has reported three live DMR frequencies from his location..
Might be worth a search of their band looking for the DMR beacon..
Mike
Mike
indeed picking up two very active freqs from the old 2217 (8A9) site. have started to compile a list of the talkgroups but will be a waste of time once it goes encripted, radiosification if you pm me i can supply you the actual freqs and colourcodes/timeslotsradiosification wrote: ↑07 Nov 2018, 22:11I'm rather disappointed, I can't hear the new DMR system still
- Metradio
- Call Sign: G7HID
Rereading the original TFL tendering requirements, was to have the "ability for encryption" and am not 100% they will implement the facility - only time will tell..
If you have a DMR receiver, the active frequencies can be found by searching between 139.500 and 140.500MHz, the active frequencies send out a constant beacon so are easily found..
Mike
Mike
- Metradio
- Call Sign: G7HID
Looks like they are in the midst of changing over today, many channels now DMR..
Mike
Mike
- Call Sign: Rich
Lots of bad feedback on my company intranet forum about the new system.
Problems reported from controllers that radios are picking up too much background noise and not enough voice. There's also comments about bad coverage in some areas (Orpington) and alert tones being far too loud.
It seems they've switched users over before testing thoroughly!
Rich
- Metradio
- Call Sign: G7HID
Sounds about right...
Mike
- 26TM944
- Call Sign: 26TM944
I am still seeing a mixture of MPT and DMR now and some DMR site(s) have enabled encryption.
Currently, the old MPT control channels are still running and at the same power levels. I still see some traffic daytimes. However, a vast number of bus companies have moved over to the Tait/Hytera system.
Time will tell if they all go encrypted.
26-TM-944
- A rig, twig & burner.
- Metradio
- Call Sign: G7HID
What sites have enabled encryption ?
Mike
Mike
personally i cant see them going encrypted anytime soon, as at the moment when the driver speaks, it sounds like machine gun fire lol
- Metradio
- Call Sign: G7HID
All the London Bus sites I can hear are still in the clear..
Mike
Mike
