London Bus change over to DMR
Scanning radio frequencies for the South East
Metradio
Call Sign: G7HID
Post by Metradio » 04 Nov 2018, 14:02
Testing of the London Bus DMR Network has started. From where I live I am receiving DMR in the clear from them on 139.66875MHz, this has been receivable for the last 3 weeks or so. Eventualy the system will be encrypted.
Their current MPT1327 and the new DMR Tier III system use the frequencies between 139.500 and 140.500MHz..
Mike
http://www.landmobile.co.uk/news/tait-t ... act-award/
Wiggler
Re: London Bus change over to DMR
Post by Wiggler » 07 Nov 2018, 15:32
Does this testing and upcoming change explain why I can now hear drivers on the 1to1 calls? In the past I could only hear the controller during 1to1 calls but on on group calls I could hear all drivers on the route. Now I can hear both sides all the time.
Metradio
Call Sign: G7HID
Post by Metradio » 07 Nov 2018, 16:37
Yes I think it does...
Mike
radiosification
Post by radiosification » 07 Nov 2018, 22:11
I'm rather disappointed, I can't hear the new DMR system still
Metradio
Call Sign: G7HID
Post by Metradio » 08 Nov 2018, 10:01
From Slough I can only pick up the one frequency, but a listener East of London has reported three live DMR frequencies from his location..
Might be worth a search of their band looking for the DMR beacon..
Mike
trainspotter375
Post by trainspotter375 » 21 Nov 2018, 12:44
radiosification wrote:
07 Nov 2018, 22:11
indeed picking up two very active freqs from the old 2217 (8A9) site. have started to compile a list of the talkgroups but will be a waste of time once it goes encripted, radiosification if you pm me i can supply you the actual freqs and colourcodes/timeslots
Metradio
Call Sign: G7HID
Post by Metradio » 21 Nov 2018, 14:40
Rereading the original TFL tendering requirements, was to have the "ability for encryption" and am not 100% they will implement the facility - only time will tell..
If you have a DMR receiver, the active frequencies can be found by searching between 139.500 and 140.500MHz, the active frequencies send out a constant beacon so are easily found..
Mike
Metradio
Call Sign: G7HID
Post by Metradio » 30 Nov 2018, 18:35
Looks like they are in the midst of changing over today, many channels now DMR..
Mike
radtech
Call Sign: Rich
Post by radtech » 01 Dec 2018, 15:24
Lots of bad feedback on my company intranet forum about the new system.
Problems reported from controllers that radios are picking up too much background noise and not enough voice. There's also comments about bad coverage in some areas (Orpington) and alert tones being far too loud.
It seems they've switched users over before testing thoroughly!
Rich
Metradio
Call Sign: G7HID
Post by Metradio » 01 Dec 2018, 18:55
radtech wrote:
01 Dec 2018, 15:24
....It seems they've switched users over before testing thoroughly!
Sounds about right...
Mike
26TM944
Call Sign: 26TM944
Post by 26TM944 » 24 Jan 2019, 16:59
I am still seeing a mixture of MPT and DMR now and some DMR site(s) have enabled encryption.
Currently, the old MPT control channels are still running and at the same power levels. I still see some traffic daytimes. However, a vast number of bus companies have moved over to the Tait/Hytera system.
Time will tell if they all go encrypted.
26-TM-944
  • A rig, twig & burner.
Metradio
Call Sign: G7HID
Post by Metradio » 24 Jan 2019, 18:16
What sites have enabled encryption ?
Mike
trainspotter375
Post by trainspotter375 » 06 Feb 2019, 09:08
personally i cant see them going encrypted anytime soon, as at the moment when the driver speaks, it sounds like machine gun fire lol
Metradio
Call Sign: G7HID
Post by Metradio » 06 Feb 2019, 09:15
All the London Bus sites I can hear are still in the clear..
Mike
