Superstar 360FM Photo
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Anyone have a high res photo of the vanilla wiring from board to switches/pots on a PB0101AB Chassis?
30TM399 Northern Costa Blanca
Otter
Call Sign: 26TM439
Re: Superstar 360FM Photo
Post by Otter »
It's not a picture, but the wiring is detailed in the service manual for the Cobra 148GTL-DX on CB Tricks.
http://www.cbtricks.com/radios/cobra/14 ... g35_36.pdf
163TM847
Post by 163TM847 »
The holes for the wires are marked too which is handy, For example "Vol M" would go to middle pin of volume control etc etc.
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Great - Thanks guys
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Black Spirit wrote: 17 May 2018, 18:53 The holes for the wires are marked too which is handy, For example "Vol M" would go to middle pin of volume control etc etc.
I might be missing the markings??? Is it on the link?
Otter
Call Sign: 26TM439
Post by Otter »
The markings are on the PCB in your radio, not on the wiring diagram.
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Didn't know if I was missing something on the diagram too :D
Thanks all.....
I'm reconstructing a 360FM which has been butchered which is missing there three band switch.... Hens teeth!
The wiring from the switch has been hacked out but the remnants of PINK and possible GREY go to a diode at MX(2). Clearly part of the mod/hack!
I've located MX(1) for Violet
Yellow at SFT ????????
Black at N ??????
If these are right looking to house PINK and GREY?
14CS06
Post by 14CS06 »
Hello
PINK and GREY here
Claude
radiogaga
Call Sign: 26TM399
Post by radiogaga »
14CS06 wrote: 18 May 2018, 17:06 Hello
PINK and GREY here
Claude
Thanks :wave:
163TM847
Post by 163TM847 »
You can get three way band switches from ebay [https://www.ebay.com/itm/2pc-Rotary-Swi ... 100623.m-1] MX1=LOW BAND, MX2=MID BAND, MX3=HIGH BAND, 8V For band switch comes from the 8v supply on the mode switch, SFT wire that goes to the band switch switches to ground when on Low and Mid band but you can wire SFT directly to ground
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Black Spirit wrote: 19 May 2018, 13:13 You can get three way band switches from ebay [https://www.ebay.com/itm/2pc-Rotary-Swi ... 100623.m-1] MX1=LOW BAND, MX2=MID BAND, MX3=HIGH BAND, 8V For band switch comes from the 8v supply on the mode switch, SFT wire that goes to the band switch switches to ground when on Low and Mid band but you can wire SFT directly to ground
Superb, hunted for ages, thanks.
I may come back to when the switch arrives, not sure I follow the last line regarding the Direct grounding.
163TM847
Post by 163TM847 »
On the band switch there will be your 8v input, then the three bands, then there is a yellow wire that comes up from the main board marked SFT [You will see SFT hole near the 15.000 crystal], This SFT will connect to the band switch on pins 1 and 2 and a ground from input, So when your on Low or Mid the SFT is grounded, But you dont really need to connect the SFT wire to the band switch you could if you wanted too connect it directly to ground.
If SFT is left ungrounded you may have trouble locking the three bands, Well they may lock but you will get a "howl" noise on the bottom end.
cb4ever104
Post by cb4ever104 »
I love these types of jobs . Stripping down the "front end" , and rebuilding it from scratch . Great fun ! :)
radiogaga
Call Sign: 26TM399
Post by radiogaga »
I'm hopeful come the arrival of the new band switch.
currentstatus
Post by currentstatus »
More pics..
