White Stick Antenna Connection?
- welshevo
- Call Sign: 163TM995
having owned this antenna for years i decided to actually use it... i connected this to my SDR using a SO239 too SMA....and got pretty rubbish results... local DMR weak... 70cms WEAK! so thought hmmmm ill bin it.... then noticed on another selling site it states this antenna uses "N" type connectors? now having looked im confused.... could someone tell me the correct connection ????
see the pic attached of the bottom of the antenna and connection?
Tetra is a Lonely place! Get DMR instead! (163TM995) ......
- MrWeetabix
- Admin
- Call Sign: 26TM175
Re: White Stick Antenna Connection?
SO239 right there
So a standard PL259 will fit
- welshevo
why does every where state N type? and why was the reception so rubbish? my little mag out performs my white stick! .....
- Call Sign: DF2TB
What you have looks like N not SO239
Andreas DF2TB
Andreas DF2TB
- Buick Mackane
- Moderator
Looks like an N-Type to me too
- MrWeetabix
- Admin
The 4 notches suggest SO239 to me...
A typical N-Type doesn't have them...
- MrWeetabix
- Admin
There can often be multiple manufacturers of similar antennas too, with differing connection types
- welshevo
its very confusing isnt it? what would anyone suggest i do ? as dont want to bin it if its going to out perform my mag with the correct connection
- Buick Mackane
- Moderator
Whats the make/model number ?
- welshevo
im lead to believe its the X30 antenna? white stick...
- Buick Mackane
- Moderator
- welshevo
https://www.amazon.co.uk/X-30-COLLINEAR ... 30+antenna
Look at the first review.... it states there its an N connector?
- Buick Mackane
- Moderator
Looks like i was right the first time, Weety grab your coat on your way out and take those cereal bowls with youwelshevo wrote: ↑21 Feb 2018, 16:31 https://www.amazon.co.uk/X-30-COLLINEAR ... 30+antenna
- 26TM931
That is definitely a SO-239 it is very rare the put "N" Types onBuick Mackane wrote: ↑21 Feb 2018, 16:36Looks like i was right the first time, Weety grab your coat on your way out and take those cereal bowls with youwelshevo wrote: ↑21 Feb 2018, 16:31 https://www.amazon.co.uk/X-30-COLLINEAR ... 30+antenna
Although it looks a cheep one and could have been fitted as a aftermarket one
- welshevo
so lets say its a N type connector and ive been using an SO239 would this cause problems in RX or TX? because the other culprit could be the coax? and not only the connectors?
