micro UHF handies ?
gmham
Call Sign: 108TM154
micro UHF handies ?
Post by gmham »
miniature handies ? see the tiny little UHF wideband handies often advertised within the banners here on TM1 on sale via bangood. anyone here used one ?
https://www.banggood.com/KALOAD-V1-1-Pc ... 7QodilcHzg
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
thelad
Re: micro UHF handies ?
Post by thelad »
Cant see the battery lasting long!
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
gmham
Call Sign: 108TM154
Post by gmham »
yep your right probably uses a watch battery given the size off the thing !!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Freddie
Post by Freddie »
Did you end up buying a pair gmham?
I've had my eye on them for a little while...
grafter
Post by grafter »
thelad wrote: 09 Oct 2017, 18:32 Cant see the battery lasting long!
Long enough to get your message to the other side of the high wall, and small enough to poke it somewhere the screws won't find it :lol:
Radiotronics
Post by Radiotronics »
The specification says 0.5w output power. You could get a few hours use from a decent 2400mAh 3.7V battery. So it might be ok on battery life. Then again, it says it has a 300mAh polymer lithium battery. Perhaps max 2-3 hours in that case. But take a look at the Motorola CLP and Motorola CLK. They both have relatively tiny batteries and can last a whole working day!
Two Way Radio Specialist
gmham
Call Sign: 108TM154
Post by gmham »
Freddie wrote: 13 Jan 2018, 16:22 Did you end up buying a pair gmham?
sorry missed your message.. nope to be honest just caught my eye no intention off buying.. he says :ugeek:
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
stanogs68
Post by stanogs68 »
they have got to be useless ,the sizeof them ,there again you can get mobile phones that small that work !!
love your familly
