loft antenna
loft antenna
hi , i have moved house and i cannot put up a long wire outside ...can someone tell me what antenna i can build to put in the loft .....i would like to make a loop antenna if possible ...if not a loop antenna i can put a long wire up but how long should it be for all band monitoring my loft is 12 feet long 8 foot wide and 7 feet high....i know this will be a compramise ...but that is the only space i have..
Re: loft antenna
Hi gerald123. Google. Diy Indoor dipole antenna and slim jim antenna and the qrp antenna design handbook .but if you got 12feet total space availble id divide bare wire in half Ie a 6 feet wire each side and then center connect your coax feed to dipole ie make a indoor dipole or option 2 put a long wire dipole under/along gutter outside on clear side of your loft for opitum rx/tx. but either way but sure to use h d copper ground wire and ground pole/ stake in ground to lightning proof antenna .. . Hope this helps you bro.cheers n 73's
Re: loft antenna
thanks speeddemon for the advice will look into that...
- Andy
Re: loft antenna
Hi Gerald. I've only just spotted this thread, so I'm probably too late. Over the years, I've found a large wire loop to be very effective. Completely untuned, just connect the ends across your coax. It will have peaks and dips across its range, but you'll find it works well from LF to HF.
'SOMEONE GET ME A SAW!'
Andy.
Andy.
- Adriano9966
Re: loft antenna
Is it for receiving or also transmitting ?
If it is for transmitting the space you have should be enough for a working loop from 20 metres to 10 metres
if you follow the contours of the roof this should give you 12' x12' ......... Loops do not need to be perfectly straight .
If you place a 4:1 balun at the feedpoint this should help you to match across several bands .
Your attic seems to be the same size as on my house and I have built a similar loop in my attic made out of thick earth cable.
My first contact yielded Svalbard on 15 metres from my poor location using 4 watts SSB .
It is a compromise antenna but it never ceases to amaze me how well it works from inside an attic with a slate roof above it.
good luck with your project
Re: loft antenna
thank you for the post...i will try the loop you that you sugested thanks...Andy wrote: ↑18 Dec 2017, 11:29 Hi Gerald. I've only just spotted this thread, so I'm probably too late. Over the years, I've found a large wire loop to be very effective. Completely untuned, just connect the ends across your coax. It will have peaks and dips across its range, but you'll find it works well from LF to HF.
- Andy
Re: loft antenna
I'm assuming this antenna is for RX only. Obviously the match of the loop would be too poor for TX at some frequencies.
Andy.
Andy.
Re: loft antenna
Use a antenna matchbox ... thats why there are made for. but For opitum rx/tx best to have any homebrew or any china companies designed antenna mounted outside in open space whenever possible . Cheers
Re: loft antenna
ok thank you for the advice.speeddemon wrote: ↑19 Dec 2017, 21:09 Use a antenna matchbox ... thats why there are made for. but For opitum rx/tx best to have any homebrew or any china companies designed antenna mounted outside in open space whenever possible . Cheers
Re: loft antenna
Indoor antenna will pick man made interference the most.
I suggest go for LW antenna made of 0.3-0.4mm enamelled copper wire. It will be invisible, but gonna work.
