What coax for HF ?
gmham
Call Sign: 108TM154
What coax for HF ?
Post by gmham »
Guys what coax you using on HF ? Looking for around 8 mtrs off RG8 mini. Okay as far losses go on this sort off length and okay for full legal limit power handling ? rg213 is a bit heavy duty on this particular antenna arrangement but would use if necessary.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Re: What coax for HF ?
Post by ch25 »
And full legal is 1500 or.... ?
@28MHZ it would be 0,257dB loss, so no matter.
gmham
Call Sign: 108TM154
Post by gmham »
400 watts... 1500? High power permit, you still get them nowadays?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Post by ch25 »
Depends on country. I can use 1500W legally.
400W is power rg8 can handle. No worry.
gmham
Call Sign: 108TM154
Post by gmham »
Cheers Chris was not too sure but guess especially with it being ssb modes 400w would not be a problem. Not too bad a losses either with quality rg8 mini on this sort off length ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Post by ch25 »
6 dB is 1s unit, so coax loss mentioned is minimal.
gmham
Call Sign: 108TM154
Post by gmham »
Perfect, quality rg8 mini just ordered. Thanks.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Post by ch25 »
Just watch that video https://www.youtube.com/watch?v=6e_ppym4yhg
Explains a lot.
gmham
Call Sign: 108TM154
Post by gmham »
Thanks Chris will check that out.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
