New 11mtr vertical required ?
gmham
Call Sign: 108TM154
Post by gmham »
In the market for a new 10/11mtr vertical. Thinking off the Sirio 827 / Sirio 2016 etc.. any difference between the two ? Any strengthening mods required on them ? Anything else worth considering .. Tornado 27 new ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Re: New 11mtr vertical required ?
Post by ch25 »
2016 need strengthening of L shaped mast mount. Usually bend under a wind. Otherwise is a good antenna.
gmham
Call Sign: 108TM154
Post by gmham »
Okay cheers so might be better with the 827 ?
anyone here owned them both be interested how they compare performance wise ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Post by ch25 »
I doubt there is anyone had them three at the same time, mounted at the same height to compare :) If not, it will be just guessing.
gmham
Call Sign: 108TM154
Post by gmham »
Yep sorry really meant between the 827 and the 2016..
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Post by ch25 »
Hard to say.
When i test different antennas or tune them I use low power transmitter located circa 500m from antenna. Always same place, same height and power.
According to that test I can tell if one antenna is better or worst than the other.
mof000
Post by mof000 »
Oggy has just done a review of the Vortex quasar v2
https://www.youtube.com/watch?v=Uq0ulNbKlWo&t=75s
I'll pay whatever i think it's worth...:-)
Post by ch25 »
Shallow review I would say. Similar results you can get by connecting curtain rail to radio.
Post by The Collector »
Am I right in thinking that Shogun's RX wasn't quite right on the vid?
ROTEL240
Post by ROTEL240 »
Dont discount the cheaper sirio GPE27 5/8th wave its a well made cracking dx antenna
NightProwler
Call Sign: 163TM186
Post by NightProwler »
ROTEL240 wrote:Dont discount the cheaper sirio GPE27 5/8th wave its a well made cracking dx antenna
I'll second that. I put one up for a friend of mine a while back and the build quality is excellent :thumbup:
Oggy
Post by Oggy »
ch25 wrote:Shallow review I would say. Similar results you can get by connecting curtain rail to radio.
I would like to see your curtain rail.....shallow, Shallow Hal
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
Usual ch25 statement shallow shallow as it is still at least this time he has put forward a better antenna in his mind HIS CURTAIN RAIL now all we need to know is where can we buy one from B&Q may be ???
Oggy
Post by Oggy »
WARLOCK wrote:Usual ch25 statement shallow shallow as it is still at least this time he has put forward a better antenna in his mind HIS CURTAIN RAIL now all we need to know is where can we buy one from B&Q may be ???
I look forward to his "Curtain Rail" review......maybe he will share a youtube link?.
Just maybe the CR special will match this antenna with just 3 watts of input....I wait with excitement. :think:
I see he has plenty to say when ever I get mentioned.
viewtopic.php?f=2&t=54062
Bigdave
Post by Bigdave »
I went for the swish curtain rail as it was more expensive, so it must be much better can't get the fecking swr down though........................
26 TM 1248
WINNER of INB4TL, the big battle edition 16/07/23
OFTEN IMITATED,BUT NEVER INTIMIDATED.
WINNER of INB4TL,the no interest edition 18/03/24
