Strange Lincoln mod?
Maybe it's a common one, can't say I'm that well up on them. But would be interested to know what it's doing...?
Some sort of tx relay, tie wrapped in, then a transistor and a resistor added between the two "Don't ADJ" signs..
Any ideas?
Cheers, Paul.
Any ideas?
Cheers, Paul.
Build a man a fire, he'll be warm for a night. Set a man on fire and he'll be warm for the rest of his life.
- Otter
- Call Sign: 26TM439
Re: Strange Lincoln mod?
Possibly to eliminate talkback?
Seems to add up. It definately fires the relay on Tx...
Thanks.
Thanks.
- NUBSTER
- Call Sign: 26TM545
Is it a old original Lincoln from the 80's /90's or one of the new ones based on the Anyclone radios ? cos if it's a old school one the don't have talk back fitted and TBH looking at that PCB in the pic it looks like a original one.
It's a 1999 model according to the sticker on the top. Output is a mrf 455 if that helps.
Cheers.
Cheers.
- sickboy
The original Lincoln did indeed have talkback fitted and it looks like that's what the modification is.
See here...
https://www.manualslib.com/manual/84011 ... ml?page=13
See here...
Embrace your inner muppet !
I'm not even sure what "talkback" is tbh?
Thanks all.
Thanks all.
- NUBSTER
Didnt know that, mine and two of my mates who own originals don't have any talk back fitted, so most of them ,must have had them removed cos TBH I haven't com across one with it fitted
Me neither! Never heard of it before! Have googled what it was now though...
Thanks everyone! That puts that to bed!
- NightProwler
- Call Sign: 163TM186
I had the same mod with the relay in my 2830 but I removed it and done it the neater way.
- astradyne
- Moderator
In the1999 version there was no talkback feature. This was only present in the very first Lincoln's/2830's manufactured in Taiwan (with the grey control knobs). People generally disliked it so had mods done to remove the talkback feature.FAFFER wrote:It's a 1999 model according to the sticker on the top. Output is a mrf 455 if that helps.
Cheers.
The talkback feature was factory removed from the radio's on the second run (with the black control knobs) which were made in the Philippines.
Having the MRF455 output yours is definitely a very late model, so should have no need at all for the talkback mod.
I know what you're saying...
But this mod is there...so, no idea!
- astradyne
- Moderator
The relay would be there to disconnect the audio to the speaker during RX and stop the tailback.FAFFER wrote:I know what you're saying...
Is there a wire going from the relay to the internal speaker?
No I don't think so. I just think the blue and white wires go to the other side of the board.
My mate has it now, it works fine! We were just interested in wtf it was!
