11Mtr Packet - PSK31 - is anyone using it?
- DX-Digger
- Call Sign: TM205
Re: 11Mtr Packet - PSK31 - is anyone using it?
One thing to be aware of with the baycom modems is they use power from the serial port to power the board. This can lead to a few issues, so If you are going to try a baycom modem using a TCM3105 which are getting rare now, I suggest you find a design that has an external power supply connection.
On the other hand, how about building your own TNC using an arduino nano?
http://www.m0pzt.com/blog/arduino-kiss-tnc/
Then you can use G8BPQ node software or TPK program or F6FBB BBS software.
or UIView for APRS tracking or AGW packet engine, or maybe Winpak?
Or run it on a Raspberry-pi maybe
http://www.prinmath.com/ham/howto/quickstart/
How about a TNC-pi or a TNC-x
http://tnc-x.com/TNCPi.htm
Lots of install and setup info available @
http://www.prinmath.com/ham/rPiHowto.htm
I fancy a play just for the hell of it.
- Black_Pirate
- Call Sign: 26TM034
the soundcard software by UZ7....is easy to try and alot more sensitive nowadays :-)
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
- ghost123uk
- Call Sign: 26TM953
I have been experimenting with PSK31 (on a Stalker 9FDX) using fldigi running on a very modest laptop (using Linux). I am only using simple resistive attenuation for the audio in & out from rig to soundcard. For now, because of the problem of finding a simple relay, running off the pins of a serial port, I have been PTT'ing using a toggle switch!! It all seems to work.
Now, I don't want to get into too much complication and expence by building and using Rasberry Pi type stuff. I am however considering buying one of those "proper" (~£27) interfaces, as linked to further up here by Black_Pirate.
I write all this because I was wondering if someone could explain, in simple terms, what is the difference between some of the other "boxes" that have been mentioned, such as TNC, TNC-X and even the Baycom modem (that I used to own, so many years ago that I cannot remember what it did).
(I am guessing that they don't use the PC soundcard but are fed by digital information from a serial port, and they convert it into audio?)
"proper" £27 interface has galvanic isolation with transformers and optocoupler for PTT. It uses computer's sound card and CPU to do the modem stuff in software.
Baycom is a kiss TNC (keep it simple) that uses control signals in a serial port to bit-bang a modem chip to do the modulation and demodulation of bell202 afsk. Computer handles the data bit-by-bit.
TNC-X is based on a microcontroller and a modem IC and uses proper serial port communication with a computer. It is still a KISS TNC, so it cannot function without a computer like a real TNC can.
For curiosity, what radio do you use? If I can get a hold of the schematics of the radio I could probably come up with a PTT control circuit that fits your radio.
- ghost123uk
Cheers for the info ^^^
Thanks for the thought, but I'm thinking that all this isolation transformer stuff that you (and others) have mentioned must be quite important (for some reason ??) so perhaps, if I am going ahead with this, I should just buy one of these boxes (thanks to Black_Pirate for the heads up) as that, I think, has all I need and will PTT via the DTR / RTS serial port pins that fldigi uses. Am I right?
Stalker 9FDX, there is a good quality circuit diagram HEREMikeSierra wrote:For curiosity, what radio do you use? If I can get a hold of the schematics of the radio I could probably come up with a PTT control circuit that fits your radio.
It seems you would need a PTT relay to replace the mike. Microphone audio probably gets cut out by the transistor close to C115, but RX control seems to do quite a bit in the radio. I cannot promise that PTT (TX) alone will do it.ghost123uk wrote:Cheers for the info ^^^
It would be wise to contact M0AQC before buying his box, because the box will not necessarily work with your radio.
(from: http://www.g0hwc.com/sstv_interface.html )ghost123uk wrote: If only there was a simple (cheap) RS232 to DPDT relay board using the fldigi industry standard DTR / RTS pins for "Hi-low" switching
I have, (as mentioned above) tested my (simple resistive audio attenuated) system on air, via fldigi under Linux (on a laptop) and it works fine. I'm just stuck with manual PTT switching via that toggle switch
I would also recommend to cut the microphone line when transmitting.
Start soldering
Is there still some activity regarding PSK31? Recently I finished my setup. Now I am trying to find out which channel and time gives the best chance of meeting someone. I am from the west coast of Holland btw.
- MrWeetabix
- Admin
- Call Sign: 26TM175
I've had all my 11m PSK31 contacts on 27.500. Give that a whirl
- ghost123uk
Due to a big change of circumstances, I have not only not had chance to continue me experiments with this, I have not been on here for ages either.
Very soon both of those topics will be rectified
Looking forward to hear you're experiences. I received my transceiver interface yesterday. The final step is to tidy everything up and make the setup more mobile then the real testing can start.
Setup for now. Yaesu FT-817nd. XGGCOMMS interface to a Raspberry PI 3 running FLDIGI. Controls through keyboard and 10 inch touchscreen. It seems to work well for the limited testing I have done.
Yesterday I have been playing around with FLdigi. I turns out it has the ability to automatically report received PSK31 transmissions to https://www.pskreporter.info/pskmap.html. It even includes the 11 meter band. I am thinking about setting up a dedicated listening station to capture activity and find out what's happening and what the best times are to get on air. This makes it a bit easier to make futere contacts.
Besides 27.500 mhz what could be a good channel for monitoring?
- Phoenix
Can anyone confirm they have managed to work any PSK /PACKET with a Uniden Boarded Radio say a Cobra 148 if so do you have the interface details thanks
26TM114
Interface details: https://easyeda.com/Midas/interface-ded ... 6680a5948a
- MrWeetabix
- Admin
Anyone still using PSK31 out there? I had a beacon running last week but heard nothing
