D TYPE EARPIECE
D TYPE EARPIECE
I am saving up for the icom id-51e plus 2 radio and I will need a D type earpiece for the unit so I can use with Raynet.
- Metradio
- Call Sign: G7HID
Re: D TYPE EARPIECE
How long a cable will you need ? Will you be wearing the ID-51E on your belt or on your stab vest ?
Mike
Mike
Re: D TYPE EARPIECE
Good question and I don't know yet so I may need a cable to connect it to the radio and the D type earpiece and that should be more easy.
- Mitch
- Call Sign: M1TCH
Re: D TYPE EARPIECE
I've got one of these 'D' earpieces (had it ages) and the lead is 1.5m long with a single mono 3.5mm jack plug. It likes being in the 'ear' socket too, not 'speaker' else it's too loud. If you want to TX as well you'll need a mic, I use an Alinco speaker mic (same pins as Icom) and that has an earphone socket at the bottom (as well as vol control), so I plug the mic into the radio and D earpiece into the mic which works well enough. Something similar could suit your needs, plug 'n play no messin'.
The perfect face for radio.
Re: D TYPE EARPIECE
I have had a look round for a D type earpiece and I have found this one at http://www.thunderpole.co.uk/d-shape-ea ... radios.htm so will it fit a Icom id51e plus 2.
- LeakyFeeder
Re: D TYPE EARPIECE
Stab vestMetradio wrote:How long a cable will you need ? Will you be wearing the ID-51E on your belt or on your stab vest ?
Mike
- Metradio
- Call Sign: G7HID
Re: D TYPE EARPIECE
Hook, line and sinkerLeakyFeeder wrote:...Stab vest
Mike
- Mitch
- Call Sign: M1TCH
Re: D TYPE EARPIECE
That looks the job, just be sure the plug will fit the radio without knobs or aerials in the way. I've got some Baofeng ones with the clear curly earpiece, now they look the bizknight wrote:I have had a look round for a D type earpiece and I have found this one at link so will it fit a Icom id51e plus 2.
